7.6.2 Expected Credit Loss Overview by Organization Unit
This is the second canvas under Expected Credit Loss Overview Reports. The pinned filters are enough to generate the report. The organization unit is a hierarchy-based dimension. This report will provide information on ECL-related measures at various IFRS 9 stages and the organization unit hierarchy levels. This canvas supports both Standalone and consolidated reports.
To generate the below reports following dimensions are used: As of date, Modelling Set, ECL and Amortization Process, Consolidation Type, Legal Entity Node, and Reporting Currency Name.
Allowance Stage Wise Overview by Organization Unit
This report displays Allowance in both absolute and percentage terms across IFRS 9 Stages.
Figure 7-111 Allowance Stage Wise Overview by Organization Unit
Figure 7-112 Allowance Stage Wise Overview by Organization Unit
Provision Stage Wise Overview by Organization Unit
This report displays Provision in both absolute and percentage terms across IFRS 9 Stages.
Figure 7-113 Provision Stage Wise Overview by Organization Unit
Figure 7-114 Provision Stage Wise Overview by Organization Unit
ECL Stage Wise Overview by Organization Unit
This report displays ECL in both absolute and percentage terms across IFRS 9 Stages.
Figure 7-115 ECL Stage Wise Overview by Organization Unit
Figure 7-116 ECL Stage Wise Overview by Organization Unit
EAD Stage Wise Overview by Organization Unit
This report displays EAD in both absolute and percentage terms across IFRS 9 Stages.
Figure 7-117 EAD Stage Wise Overview by Organization Unit
Figure 7-118 EAD Stage Wise Overview by Organization Unit
ECL Stage Wise Overview based on Account Classification by Org Unit
This report displays ECL in both absolute and percentage terms across account classifications.
Figure 7-119 ECL Stage Wise Overview based on Account Classification by Org Unit
Figure 7-120 EAD Stage Wise Overview by Organization Unit
Impairment Gain/Loss Overview by Organization Unit
This report displays Impairment Gain/Loss in both absolute and percentage terms across IFRS 9 Stages.
Figure 7-121 Impairment Gain/Loss Overview by Organization Unit
ECL Adjustment Overview by Org Unit
Figure 7-122 ECL Adjustment Overview by Org Unit
- For New Accounts: The adjustment is equal to the Final ECL of the current period.
- For Existing Accounts: The adjustment is calculated as the difference between the Final ECL of the current period and the Final ECL of the previous period.
