7.6.4 Expected Credit Loss Overview by Product
This is the fourth canvas under Expected Credit Loss Overview Reports. The pinned filters and dimension-based filter Product Node is required to generate this report. The product is a hierarchy-based dimension. This report will provide information on ECL-related measures at various IFRS 9 stages and product hierarchy levels. This canvas supports both Standalone and consolidated reports.
To generate the below reports following dimensions are used: As of date, Modelling Set, ECL and Amortization Process, Consolidation Type, Legal Entity Node, and Reporting Currency Name.
Allowance Stage Wise Overview by Product
Figure 7-135 Allowance Stage Wise Overview by Product
Figure 7-136 Allowance Stage Wise Overview by Product
Provision Stage Wise Overview by Product
This report displays Provision in both absolute and percentage terms across IFRS 9 Stages.
Figure 7-137 Provision Stage Wise Overview by Product
Figure 7-138 Provision Stage Wise Overview by Product
ECL Stage Wise Overview by Product
This report displays ECL in both absolute and percentage terms across IFRS 9 Stages.
Figure 7-139 ECL Stage Wise Overview by Product
Figure 7-140 ECL Stage Wise Overview by Product
EAD Stage Wise Overview by Product
This report displays EAD in both absolute and percentage terms across IFRS 9 Stages.
Figure 7-141 EAD Stage Wise Overview by Product
Figure 7-142 EAD Stage Wise Overview by Product
ECL Stage Wise Overview based on Account Classification by Product
This report displays ECL in both absolute and percentage terms across account classifications.
Figure 7-143 ECL Stage Wise Overview based on Account Classification by Product
Figure 7-144 ECL Stage Wise Overview based on Account Classification by Product Hierarchy
Impairment Gain/Loss Overview by Product
This report displays Impairment Gain/Loss in both absolute and percentage terms across IFRS 9 Stages.
Figure 7-145 Impairment Gain/Loss Overview by Product
ECL Adjustment Overview by Product
Figure 7-146 ECL Adjustment Overview by Product
- For New Accounts: The adjustment is equal to the Final ECL of the current period.
- For Existing Accounts: The adjustment is calculated as the difference between the Final ECL of the current period and the Final ECL of the previous period.
