2.3 Create Cash Flow Edits Rule
To add a new Cash Flow Edits Rule, follow these steps:
  1. Navigate to Cash Flow Edits Summary Page.
  2. Click the Add icon. The Add Cash Flow Edits Rule Window is displayed.
    Figure 2-2 Add Cash Flow Edits Rule
  3. Enter the following details:
    Table 2-3 List of fields used for Creating Cash Flow Edits Process
    Field Description
    Rule ID Shows the ID of the Cash Flow Edits Rule. This is an auto generated numeric field. You cannot modify this.
    Rule Name Enter the name of the Cash Flow Edits Rule. This is an alphanumeric field. The maximum length of this field is 1000 characters.
    Group Name
    Select the Group Name from Group Name drop-down list. For example, Cash Flow. You can add new a Sub Group using Add icon.
    Adding a Sub Group
    To add a Sub Group, follow these steps:
    1. Click Add. The Add Group Window is displayed.
    2. Enter the following details:
      • Group Name: Name of new Group
      • Parent Group: Select Parent Group
      • Group Id is auto populated.
    These added Group/Sub Group Names will be populated in Cash Flow Edits Details section of Cash Flow Edits Process window.
    Access Type Select the Access Type as Read-Only or Read/Write.
    Condition ID This field shows the Condition ID. This is an auto generated numeric field. You cannot modify this.
    Condition Columns Select the Columns using which you want to define the error condition expression.
    Condition Statement
    This field allows you to define the expression of a rule. You can define condition expression for selected Condition Columns (using the Condition Columns field).
    When you click the Condition Statement Field, the Expression Window is displayed. Define the condition and click Save.
    Condition Message
    Select the Condition message. You can add a new condition message using Add icon. For more information on Cash Flow Edits messages, see the Cash Flow Edits Execution section.
    To add a Condition Message, follow these steps:
    1. Click Add icon. The Add Message Window is displayed. Enter the following details:
      • Message Type: Select as Error, Warning, or Information
      • Message Description: Enter the Message details.
      • Message ID is auto populated.
    2. Click Save.
    Update Columns Select the columns which you want to update if error condition is met
    Default Value Column Select the columns from which you want to update columns selected in Update Columns.
    Default Value Enter the values that you want to update the columns selected in Update Columns.
    Update Order If the same column is getting updated by more than one rule then the order in which each rule applies must be selected here.
    Status Set the status of the rule as Active or Inactive.
    User Defined This field shows the User Defined status as Yes or No. You cannot modify this.
    Editable Set the Editable status of rule as Yes or No.
  4. Click Save.
