2.2 Cash Flow Edits Process Errors
  • Error: Engine does not process, however sometimes default value can get used for calculations.
  • Warning: Engine may use the default value or given wrong data for calculation, results may be incorrect.
  • Info: Does not impact any processing but results may not be as expected.
  • Rule ID: 1
    Error Condition (AMRT_TYPE_CD <> 700 OR ( amrt_type_cd = 700 AND amrt_term <> 0 ) ) AND (CASE amrt_term_mult WHEN 'Y' THEN amrt_term * 365 WHEN 'M' THEN amrt_term * 30.41667 ELSE amrt_term END) < (CASE org_term_mult WHEN 'Y' THEN org_term * 365 WHEN 'M' THEN org_term * 30.41667 ELSE org_term END) THEN 'P' ELSE 'F' END
    Error Description Amortization term can only be equal to zero on Non-Amortizing instruments
    Assignment AMRT_TERM = ORG_TERM and AMRT_TERM_MULT = ORG_TERM_MULT
    Warning Original Term > Amortization Term
    Error Level Warning
  • Rule ID: 2
    Error Condition (ORIGINATION_DATE < AS_OF_DATE and CUR_PAR_BAL is not NULL and ORG_PAR_BAL is not NULL and CUR_PAR_BAL = ORG_PAR_BAL)
    Error Description Instrument has originated in past but Current Par Balance and Original Par Balance are equal
    Assignment
    Warning Current Par Balance = Original Par Balance
    Error Level Warning
  • Rule ID: 3
    Error Condition (ORIGINATION_DATE < AS_OF_DATE and DEFERRED_CUR_BAL is not NULL and DEFERRED_ORG_BAL is not NULL and DEFERRED_CUR_BAL = DEFERRED_ORG_BAL)
    Error Description Instrument has originated in past but Deferred Current Balance and Deferred Original Balance are equal
    Assignment
    Warning Deferred Current Balance = Deferred Original Balance
    Error Level Warning
  • Rule ID: 4
    Error Condition (CUR_GROSS_RATE is NULL or CUR_GROSS_RATE < 0)
    Error Description Current gross rate is negative
    Assignment
    Warning Current Gross Rate < 0
    Error Level Info
  • Rule ID: 5
    Error Condition (CUR_NET_RATE is NULL or CUR_NET_RATE < 0)
    Error Description Current net rate is negative
    Assignment
    Warning Current Net Rate < 0
    Error Level Info
  • Rule ID: 6
    Error Condition (ACCRUAL_BASIS_CD is NULL or ACCRUAL_BASIS_CD <1 or ACCRUAL_BASIS_CD >7)
    Error Description Accrual basis code must be between 1 and 7 inclusively
    Assignment ACCRUAL_BASIS_CD = 3
    Warning Invalid Accrual Basis
    Error Level Warning
  • Rule ID: 7
    Error Condition (AMRT_TYPE_CD is NULL or AMRT_TYPE_CD not in (100, 400, 600, 700, 710, 800, 801, 802, 820, 840, 850, 10, 20))
    Error Description Amortization type must be a valid OFSAA code
    Assignment AMRT_TYPE_CD = 700
    Warning Invalid Amortization Type
    Error Level Warning
  • Rule ID: 8
    Error Condition (AMRT_TYPE_CD = 20 and (PMT_PATTERN_CD is null or PMT_PATTERN_CD <= 0))
    Error Description Amortization type is Payment Pattern but Payment Pattern Code is invalid
    Warning Invalid Payment Pattern
    Error Level Warning
  • Rule ID: 9
    Error Condition (AMRT_TYPE_CD = 20 and PMT_PATTERN_CD is not null and PMT_PATTERN_CD > 0 and PMT_PATTERN_CD not in (select AMRT_TYPE_CD from fsi_payment_pattern))
    Error Description Amortization type is Payment Pattern but Payment Pattern definition does not exist
    Error Level Warning
  • Rule ID: 10
    Error Condition (AMRT_TYPE_CD = 10 and (BEHAVIOUR_PATTERN_CD is null or BEHAVIOUR_PATTERN_CD <= 0))
    Error Description Amortization type is Behaviour Pattern but Behaviour Pattern Code is invalid
    Warning Invalid Behaviour Pattern
    Error Level Warning
  • Rule ID: 11
    Error Condition (AMRT_TYPE_CD = 10 and BEHAVIOUR_PATTERN_CD is not NULL and BEHAVIOUR_PATTERN_CD > 0 and BEHAVIOUR_PATTERN_CD not in (select PATTERN_CD from fsi_behaviour_pattern_master))
    Error Description Amortization type is Behaviour Pattern but Behaviour Pattern definition does not exist
    Error Level Warning
  • Rule ID: 12
    Error Condition (AMRT_TYPE_CD in (800, 801, 802) and NOT EXISTS (select 1 from FSI_D_Payment_Schedule WHERE FSI_D_Payment_Schedule.ID_NUMBER=SOURCE_TABLE.ID_NUMBER AND FSI_D_Payment_Schedule.IDENTITY_CODE = SOURCE_TABLE.IDENTITY_CODE AND FSI_D_Payment_Schedule.INSTRUMENT_TYPE_CD = SOURCE_TABLE.INSTRUMENT_TYPE_CD))
    Error Description Cannot find record with matching ID Number, Identity Code and Instrument Type Code in Payment Schedule table
    Warning Invalid Payment schedule data
    Error Level Warning
  • Rule ID: 13
    Error Condition (AMRT_TYPE_CD in (800, 801, 802) and ORIGINATION_DATE > (select max(PAYMENT_DATE) from FSI_D_Payment_Schedule WHERE FSI_D_Payment_Schedule.ID_NUMBER=SOURCE_TABLE.ID_NUMBER AND FSI_D_Payment_Schedule.IDENTITY_CODE = SOURCE_TABLE.IDENTITY_CODE AND FSI_D_Payment_Schedule.INSTRUMENT_TYPE_CD = SOURCE_TABLE.INSTRUMENT_TYPE_CD))
    Error Description Origination Date is greater than highest date in Payment Schedule
    Error Level Warning
  • Rule ID: 14
    Error Condition (AMRT_TERM_MULT is NULL or AMRT_TERM_MULT not in ('D', 'M', 'Y'))
    Error Description Amortization term multiplier must be D, M, or Y
    Assignment AMRT_TERM_MULT = M
    Warning Invalid Amortization Term Multiplier
    Error Level Warning
  • Rule ID: 15
    Error Condition (AMRT_TYPE_CD = 600 AND (NEG_AMRT_EQ_MULT is NULL or NEG_AMRT_EQ_MULT not in ('D', 'M', 'Y')))
    Error Description Negative Amortization Equalization Frequency multiplier must be D, M, or Y
    Assignment NEG_AMRT_EQ_MULT = M
    Warning Invalid Negative Amortization Equalization Frequency Multiplier
    Error Level Warning
  • Rule ID: 16
    Error Condition (AMRT_TYPE_CD = 600 and (NEG_AMRT_LIMIT is NULL or NEG_AMRT_LIMIT >=200 or NEG_AMRT_LIMIT < 0))
    Error Description Negative Amortization limit value does not fall in a valid range (0 to 200), Applicable to Negative amortization instruments only
    Assignment NEG_AMRT_LIMIT = 0
    Warning Invalid Negative Amortization Limit
    Error Level Warning
  • Rule ID: 17
    Error Condition (ORG_TERM_MULT is NULL or ORG_TERM_MULT not in ('D', 'M', 'Y'))
    Error Description Original term multiplier must be D, M, or Y
    Assignment ORG_TERM_MULT= M
    Warning Invalid Original Term Multiplier
    Error Level Warning
  • Rule ID: 18
    Error Condition (AMRT_TYPE_CD = 600 and (NEG_AMRT_PMT_CHG_FREQ is NULL or NEG_AMRT_PMT_CHG_FREQ < 0))
    Error Description Payment Change Frequency cannot be negative, Applicable to Negative amortization instruments only
    Assignment NEG_AMRT_PMT_CHG_FREQ = 0
    Warning Invalid Negative Amortization Payment Change Frequency
    Error Level Warning
  • Rule ID: 19
    Error Condition (AMRT_TYPE_CD = 600 and (NEG_AMRT_PMT_CHG_FREQ_MULT is NULL or NEG_AMRT_PMT_CHG_FREQ_MULT not in ('D', 'M', 'Y')))
    Error Description Negative Amortization Payment Change Frequency Multiplier must be D, M, or Y
    Assignment NEG_AMRT_PMT_CHG_FREQ_MULT = M
    Warning Invalid Negative Amortization Payment Change Frequency Multiplier
    Error Level Warning
  • Rule ID: 20
    Error Condition (INT_PMT_FREQ_MULT is NULL or INT_PMT_FREQ_MULT not in ('D', 'M', 'Y'))
    Error Description Interest Payment frequency multiplier must be D, M, or Y
    Assignment INT_PMT_FREQ_MULT = M
    Warning Invalid Interest Payment Frequency Multiplier
    Error Level Warning
  • Rule ID: 21
    Error Condition (PRIN_PMT_FREQ_MULT is NULL or PRIN_PMT_FREQ_MULT not in ('D', 'M', 'Y'))
    Error Description Principal Payment frequency multiplier must be D, M, or Y
    Assignment PRIN_PMT_FREQ_MULT = M
    Warning Invalid Principal Payment Frequency Multiplier
    Error Level Warning
  • Rule ID: 22
    Error Condition (RATE_CHG_RND_CD is NULL or RATE_CHG_RND_CD < 0 or RATE_CHG_RND_CD > 4)
    Error Description Rate change round code must be between 0 and 4
    Assignment RATE_CHG_RND_CD = 0
    Warning Invalid Rate Change Rounding Code
    Error Level Warning
  • Rule ID: 23
    Error Condition (ADJUSTABLE_TYPE_CD > 0 and (RATE_SET_LAG_MULT is NULL or RATE_SET_LAG_MULT not in ('D', 'M', 'Y')))
    Error Description Rate Set Lag Multiplier must be D, M, or Y
    Assignment RATE_SET_LAG_MULT = M
    Warning Invalid Rate Set Lag Multiplier
    Error Level Warning
  • Rule ID: 24
    Error Condition (ADJUSTABLE_TYPE_CD > 0 and (REPRICE_FREQ_MULT is NULL or REPRICE_FREQ_MULT not in ('D', 'M', 'Y')))
    Error Description Repricing Frequency Multiplier must be D, M, or Y
    Assignment REPRICE_FREQ_MULT = M
    Warning Invalid Repricing Frequency Multiplier
    Error Level Warning
  • Rule ID: 25
    Error Condition (RATE_CHG_RND_FAC is NULL or RATE_CHG_RND_FAC < 0 or RATE_CHG_RND_FAC > 1)
    Error Description Rate change round factor must be between 0 and 1
    Assignment RATE_CHG_RND_FAC = 0
    Warning Invalid Rate Change Rounding Factor
    Error Level Warning
  • Rule ID: 26
    Error Condition (MATURITY_DATE < NEXT_INT_PAYMENT_DATE)
    Error Description Maturity date cannot be before the next interest payment date
    Assignment MATURITY_DATE = (CASE PRIN_PMT_FREQ_MULT WHEN 'Y' THEN ADD_MONTHS(NEXT_PRIN_PAYMENT_DATE, ((REMAIN_NO_PMTS -1)* PRIN_PMT_FREQ * 12)) WHEN 'M' THEN ADD_MONTHS(NEXT_PRIN_PAYMENT_DATE, ((REMAIN_NO_PMTS -1)* PRIN_PMT_FREQ)) ELSE NEXT_PRIN_PAYMENT_DATE + ((REMAIN_NO_PMTS -1)* PRIN_PMT_FREQ) END)
    Warning Maturity Date < Next Interest Payment Date
    Error Level Warning
  • Rule ID: 27
    Error Condition (MATURITY_DATE < NEXT_PRIN_PAYMENT_DATE)
    Error Description Maturity date cannot be before the next principal payment date
    Warning Maturity Date < Next Principal Payment Date
    Error Level Warning
  • Rule ID: 28
    Error Condition (AMRT_TYPE_CD = 600 and (NEG_AMRT_EQ_FREQ is NULL or NEG_AMRT_EQ_FREQ < 0))
    Error Description Negative amortization equalization frequency cannot be negative, Applicable to Negative amortization instruments only
    Assignment NEG_AMRT_EQ_FREQ = 0
    Warning Negative Amortization Equalization Frequency < 0
    Error Level Warning
  • Rule ID: 29
    Error Condition (AMRT_TYPE_CD = 600 and NEG_AMRT_EQ_FREQ is not null and NEG_AMRT_EQ_FREQ > 0 and NEG_AMRT_EQ_DATE <= greatest(ORIGINATION_DATE, AS_OF_DATE))
    Error Description Negative Amortization equalization date is less than origination date (future origination) or less than the as-of-date (past origination), Applicable to Negative Amortization instruments only
    Assignment NEG_AMRT_EQ_DATE = NEXT_REPRICE_DATE
    Warning Negative Amortization Equalization Date < Origination Date or As of Date
    Error Level Warning
  • Rule ID: 30
    Error Condition (AMRT_TYPE_CD = 600 and NEG_AMRT_EQ_FREQ is not NULL and NEG_AMRT_EQ_FREQ > 0 and NEG_AMRT_EQ_DATE > MATURITY_DATE)
    Error Description Next interest payment date is less than as-of-date (past origination case), As of Date cannot be greater than the origination date and greater than the next payment date.
    Warning Negative Amortization Equalization Date > Maturity Date
    Error Level Warning
  • Rule ID: 31
    Error Condition (AS_OF_DATE > ORIGINATION_DATE and AS_OF_DATE >= NEXT_INT_PAYMENT_DATE)
    Error Description Negative Amortization equalization date is after Maturity Date, Applicable to Negative Amortization instruments only
    Assignment NEXT_INT_PAYMENT_DATE = AS_OF_DATE + 1
    Warning Next Interest Payment Date < As of Date
    Error Level Warning
  • Rule ID: 32
    Error Condition (AS_OF_DATE > ORIGINATION_DATE and AS_OF_DATE >= NEXT_PRIN_PAYMENT_DATE)
    Error Description Next principal payment date is less than as-of-date (past origination case), As of Date cannot be greater than the origination date and greater than the next payment date.
    Assignment NEXT_PRIN_PAYMENT_DATE= AS_OF_DATE + 1
    Warning Next Principal Payment Date < As of Date
    Error Level Warning
  • Rule ID: 33
    Error Condition (ORIGINATION_DATE >= AS_OF_DATE and ORIGINATION_DATE >= NEXT_INT_PAYMENT_DATE)
    Error Description Next interest payment date is less than origination date (future origination case)
    Assignment NEXT_INT_PAYMENT_DATE = ORIGINATION_DATE + 1
    Warning Next Interest Payment Date < Origination Date
    Error Level Warning
  • Rule ID: 34
    Error Condition (ORIGINATION_DATE >= AS_OF_DATE and ORIGINATION_DATE >= NEXT_PRIN_PAYMENT_DATE)
    Error Description Next principal payment date is less than origination date (future origination case)
    Assignment NEXT_PRIN_PAYMENT_DATE= ORIGINATION_DATE + 1
    Warning Next Principal Payment Date < Origination Date
    Error Level Warning
  • Rule ID: 35
    Error Condition (ORIGINATION_DATE <= AS_OF_DATE and NEXT_REPRICE_DATE <= AS_OF_DATE and REPRICE_FREQ > 0)
    Error Description Next repricing date is less than as-of-date (past origination case)
    Assignment NEXT_REPRICE_DATE = AS_OF_DATE + 1
    Warning Next Reprice Date < As of Date
    Error Level Warning
  • Rule ID: 36
    Error Condition (ORIGINATION_DATE > AS_OF_DATE and NEXT_REPRICE_DATE < ORIGINATION_DATE and REPRICE_FREQ > 0)
    Error Description Next repricing date is less than the origination date (future origination case)
    Assignment NEXT_REPRICE_DATE = ORIGINATION_DATE + 1
    Warning Next Reprice Date < Origination Date
    Error Level Warning
  • Rule ID: 37
    Error Condition (AMRT_TYPE_CD = 600 and (ORG_PAYMENT_AMT is NULL or ORG_PAYMENT_AMT = 0) and NEG_AMRT_PMT_DECR_LIFE > 0)
    Error Description Payment decrease life is expressed as a percent of a original payment, Applicable to negative amortization instruments only
    Assignment NEG_AMRT_PMT_DECR_LIFE = 0
    Warning Original Payment Amount = 0 and Negative Amortization Payment Decrease Limit (Life) <> 0
    Error Level Warning
  • Rule ID: 38
    Error Condition (AMRT_TYPE_CD = 600 and (ORG_PAYMENT_AMT is NULL or ORG_PAYMENT_AMT = 0) and NEG_AMRT_PMT_INCR_LIFE > 0)
    Error Description Payment increase life is expressed as a percent of a original payment, Applicable to negative amortization instruments only
    Assignment NEG_AMRT_PMT_INCR_LIFE = 0
    Warning Original Payment Amount = 0 and Negative Amortization Payment Increase Limit (Life) <> 0
    Error Level Warning
  • Rule ID: 39
    Error Condition (ORG_TERM = 0 OR ORG_TERM <> (CASE ORG_TERM_MULT WHEN 'Y' THEN MONTHS_BETWEEN(MATURITY_DATE, ORIGINATION_DATE)*12 WHEN 'M' THEN MONTHS_BETWEEN(MATURITY_DATE, ORIGINATION_DATE) ELSE (MATURITY_DATE - ORIGINATION_DATE) END))
    Error Description Original term should equal the time between the origination date and the maturity date
    Assignment - Default Value ORG_TERM#ORG_TERM_MULT = If MONTHS_BETWEEN(MATURITY_DATE, ORIGINATION_DATE) < 1 THEN 1 ELSE MONTHS_BETWEEN(MATURITY_DATE, ORIGINATION_DATE) END#
    Warning Original Term <> Maturity Date - Orgination Date
    Error Level Warning
  • Rule ID: 40
    Error Condition (ORIGINATION_DATE is NULL or ORIGINATION_DATE < '1-Aug-1950' or ORIGINATION_DATE > '1-Aug-2099')
    Error Description Origination date must be acceptable
    Assignment ORIGINATION_DATE = 1-Jan-50
    Warning Origination date < 01/01/1950
    Error Level Warning
  • Rule ID: 41
    Error Condition (INT_PMT_FREQ > (CASE INT_PMT_FREQ_MULT WHEN 'Y' THEN MONTHS_BETWEEN(MATURITY_DATE, ORIGINATION_DATE)*12 WHEN 'M' THEN MONTHS_BETWEEN(MATURITY_DATE, ORIGINATION_DATE) ELSE (MATURITY_DATE - ORIGINATION_DATE) END))
    Error Description Interest Payment frequency cannot be greater than original term
    Assignment - Default Value INT_PMT_FREQ#INT_PMT_FREQ_MULT = If MONTHS_BETWEEN(MATURITY_DATE, ORIGINATION_DATE) < 1 THEN 1 ELSE MONTHS_BETWEEN(MATURITY_DATE, ORIGINATION_DATE) END#
    Warning Interest Payment Freq > Original Term
    Error Level Warning
  • Rule ID: 42
    Error Condition (PRIN_PMT_FREQ >(CASE PRIN_PMT_FREQ_MULT WHEN 'Y' THEN MONTHS_BETWEEN(MATURITY_DATE, ORIGINATION_DATE)*12 WHEN 'M' THEN MONTHS_BETWEEN(MATURITY_DATE, ORIGINATION_DATE) ELSE (MATURITY_DATE - ORIGINATION_DATE) END))
    Error Description Principal Payment frequency cannot be greater than original term
    Assignment - Default Value PRIN_PMT_FREQ#PRIN_PMT_FREQ_MULT= If MONTHS_BETWEEN(MATURITY_DATE, ORIGINATION_DATE) < 1 THEN 1 ELSE MONTHS_BETWEEN(MATURITY_DATE, ORIGINATION_DATE) END#
    Warning Principal Payment Freq > Original Term
    Error Level Warning
  • Rule ID: 43
    Error Condition ((CUR_PAYMENT is NULL or CUR_PAYMENT < 0 and CUR_PAR_BAL > 0) or (CUR_PAYMENT > 0 and CUR_PAR_BAL < 0))
    Error Description Current payment and current par balance cannot have opposite signs
    Assignment CUR_PAYMENT = 0
    Warning Current Payment and Current Par Balance have opposite signs
    Error Level Warning
  • Rule ID: 44
    Error Condition (AMRT_TYPE_CD = 600 and NEG_AMRT_PMT_CHG_FREQ > 0 and AS_OF_DATE > NEG_AMRT_PMT_ADJUST_DATE)
    Error Description Negative Amortization Payment Adjustment Date is less than the as-of-date (past origination), Applicable to negative amortization instruments only
    Assignment NEG_AMRT_PMT_ADJUST_DATE=NEXT_REPRICE_DATE
    Warning Negative Amortization Payment Adjustment Date < As of Date
    Error Level Warning
  • Rule ID: 45
    Error Condition (AMRT_TYPE_CD = 600 and NEG_AMRT_PMT_CHG_FREQ > 0 and AS_OF_DATE < NEG_AMRT_PMT_ADJUST_DATE and NEG_AMRT_PMT_ADJUST_DATE < ORIGINATION_DATE)
    Error Description Negative Amortization Payment adjustment date is less than origination date (future origination), Applicable to negative amortization instruments only
    Warning Negative Amortization Payment Adjustment Date < Origination Date
    Error Level Warning
  • Rule ID: 46
    Error Condition ((INT_PMT_FREQ is NULL or INT_PMT_FREQ <= 0) and ((ORIGINATION_DATE <= AS_OF_DATE and MATURITY_DATE > AS_OF_DATE) or (ORIGINATION_DATE > AS_OF_DATE and MATURITY_DATE > ORIGINATION_DATE)))
    Error Description Interest Payment frequency is less than or equal to zero, and both maturity date and origination date are valid dates and can be used to calculate payment frequency.
    Assignment NEXT_INT_PAYMENT_DATE#ORG_TERM#ORG_TERM_MULT#INT_PMT_FREQ#INT_PMT_FREQ_MULT#REMAIN_NO_PMTS=MATURITY_DATE#CASE WHEN MONTHS_BETWEEN(MATURITY_DATE, ORIGINATION_DATE) < 1 THEN 1 ELSE MONTHS_BETWEEN(MATURITY_DATE, ORIGINATION_DATE) END##CASE WHEN MONTHS_BETWEEN(MATURITY_DATE, ORIGINATION_DATE) < 1 THEN 1 ELSE MONTHS_BETWEEN(MATURITY_DATE, ORIGINATION_DATE) END##
    Warning Interest Payment Frequency <= 0
    Error Level Warning
  • Rule ID: 47
    Error Condition ((PRIN_PMT_FREQ is NULL or PRIN_PMT_FREQ <= 0) and ((ORIGINATION_DATE <= AS_OF_DATE and MATURITY_DATE > AS_OF_DATE) or (ORIGINATION_DATE > AS_OF_DATE and MATURITY_DATE > ORIGINATION_DATE)))
    Error Description Principal Payment frequency is less than or equal to zero, and both maturity date and origination date are valid dates and can be used to calculate payment frequency.
    Assignment NEXT_PRIN_PAYMENT_DATE#ORG_TERM#ORG_TERM_MULT#PRIN_PMT_FREQ#PRIN_PMT_FREQ_MULT#REMAIN_NO_PMTS=MATURITY_DATE#CASE WHEN MONTHS_BETWEEN(MATURITY_DATE, ORIGINATION_DATE) < 1 THEN 1 ELSE MONTHS_BETWEEN(MATURITY_DATE, ORIGINATION_DATE) END##CASE WHEN MONTHS_BETWEEN(MATURITY_DATE, ORIGINATION_DATE) < 1 THEN 1 ELSE MONTHS_BETWEEN(MATURITY_DATE, ORIGINATION_DATE) END##
    Warning Principal Payment Frequency <= 0
    Error Level Warning
  • Rule ID: 48
    Error Condition ((INT_PMT_FREQ is NULL or INT_PMT_FREQ <= 0) and ((ORIGINATION_DATE <= AS_OF_DATE and MATURITY_DATE <= AS_OF_DATE and NEXT_INT_PAYMENT_DATE > AS_OF_DATE) or (ORIGINATION_DATE > AS_OF_DATE AND MATURITY_DATE < ORIGINATION_DATE and NEXT_INT_PAYMENT_DATE > ORIGINATION_DATE)))
    Error Description Interest payment frequency is less than or equal to zero and maturity date is invalid, but next interest payment date can be used to calculate a valid payment frequency
    Assignment MATURITY_DATE#ORG_TERM#ORG_TERM_MULT#INT_PMT_FREQ#INT_PMT_FREQ_MULT#REMAIN_NO_PMTS=NEXT_INT_PAYMENT_DATE#CASE WHEN MONTHS_BETWEEN(MATURITY_DATE, ORIGINATION_DATE) < 1 THEN 1 ELSE MONTHS_BETWEEN(MATURITY_DATE, ORIGINATION_DATE) END##CASE WHEN MONTHS_BETWEEN(MATURITY_DATE, ORIGINATION_DATE) < 1 THEN 1 ELSE MONTHS_BETWEEN(MATURITY_DATE, ORIGINATION_DATE) END##
    Error Level Warning
  • Rule ID: 49
    Error Condition ((PRIN_PMT_FREQ is NULL or PRIN_PMT_FREQ <= 0) and ((ORIGINATION_DATE <= AS_OF_DATE and MATURITY_DATE <= AS_OF_DATE and NEXT_PRIN_PAYMENT_DATE > AS_OF_DATE) or (ORIGINATION_DATE > AS_OF_DATE AND MATURITY_DATE < ORIGINATION_DATE and NEXT_PRIN_PAYMENT_DATE > ORIGINATION_DATE)))
    Error Description Principal payment frequency is less than or equal to zero and maturity date is invalid, but next interest payment date can be used to calculate a valid payment frequency
    Assignment MATURITY_DATE#ORG_TERM#ORG_TERM_MULT#PRIN_PMT_FREQ#PRIN_PMT_FREQ_MULT#REMAIN_NO_PMTS=NEXT_PRIN_PAYMENT_DATE#CASE WHEN MONTHS_BETWEEN(MATURITY_DATE, ORIGINATION_DATE) < 1 THEN 1 ELSE MONTHS_BETWEEN(MATURITY_DATE, ORIGINATION_DATE) END##CASE WHEN MONTHS_BETWEEN(MATURITY_DATE, ORIGINATION_DATE) < 1 THEN 1 ELSE MONTHS_BETWEEN(MATURITY_DATE, ORIGINATION_DATE) END##
    Error Level Warning
  • Rule ID: 50
    Error Condition ((INT_PMT_FREQ is NULL or INT_PMT_FREQ <= 0) and ((ORIGINATION_DATE <= AS_OF_DATE and MATURITY_DATE <= AS_OF_DATE and NEXT_INT_PAYMENT_DATE <= AS_OF_DATE) or (ORIGINATION_DATE > AS_OF_DATE AND MATURITY_DATE < ORIGINATION_DATE and NEXT_INT_PAYMENT_DATE < ORIGINATION_DATE)))
    Error Description Interest payment frequency is less than or equal to zero and all dates which can be used to calculate payment frequency are in the past
    Assignment MATURITY_DATE#NEXT_INT_PAYMENT_DATE#ORG_TERM#ORG_TERM_MULT#INT_PMT_FREQ#INT_PMT_FREQ_MULT#REMAIN_NO_PMTS=AS_OF_DATE + 1#AS_OF_DATE + 1#CASE WHEN MONTHS_BETWEEN(MATURITY_DATE, ORIGINATION_DATE) < 1 THEN 1 ELSE MONTHS_BETWEEN(MATURITY_DATE, ORIGINATION_DATE) END##CASE WHEN MONTHS_BETWEEN(MATURITY_DATE, ORIGINATION_DATE) < 1 THEN 1 ELSE MONTHS_BETWEEN(MATURITY_DATE, ORIGINATION_DATE) END##
    Error Level Warning
  • Rule ID: 51
    Error Condition ((PRIN_PMT_FREQ is NULL or PRIN_PMT_FREQ <= 0) and ((ORIGINATION_DATE <= AS_OF_DATE and MATURITY_DATE <= AS_OF_DATE and NEXT_PRIN_PAYMENT_DATE <= AS_OF_DATE) or (ORIGINATION_DATE > AS_OF_DATE AND MATURITY_DATE < ORIGINATION_DATE and NEXT_PRIN_PAYMENT_DATE < ORIGINATION_DATE)))
    Error Description Principal payment frequency is less than or equal to zero and all dates which can be used to calculate payment frequency are in the past
    Assignment MATURITY_DATE#NEXT_PRIN_PAYMENT_DATE#ORG_TERM#ORG_TERM_MULT#PRIN_PMT_FREQ#PRIN_PMT_FREQ_MULT#REMAIN_NO_PMTS=AS_OF_DATE + 1#AS_OF_DATE + 1#CASE WHEN MONTHS_BETWEEN(MATURITY_DATE, ORIGINATION_DATE) < 1 THEN 1 ELSE MONTHS_BETWEEN(MATURITY_DATE, ORIGINATION_DATE) END##CASE WHEN MONTHS_BETWEEN(MATURITY_DATE, ORIGINATION_DATE) < 1 THEN 1 ELSE MONTHS_BETWEEN(MATURITY_DATE, ORIGINATION_DATE) END##
    Error Level Warning
  • Rule ID: 52
    Error Condition (AMRT_TYPE_CD = 600 and (NEG_AMRT_PMT_INCR_CYCLE is NULL or NEG_AMRT_PMT_INCR_CYCLE < 0))
    Error Description Negative Amortization Payment increase limit (cycle) cannot be less than zero, Applicable to negative amortization instruments only
    Assignment NEG_AMRT_PMT_INCR_CYCLE=0
    Warning Negative Amortization Payment Increase Limit (Cycle) < 0
    Error Level Warning
  • Rule ID: 53
    Error Condition (RATE_CAP_LIFE < CUR_GROSS_RATE and RATE_CAP_LIFE <> 0 and CUR_GROSS_RATE <> 0 and TEASER_END_DATE < AS_OF_DATE)
    Error Description Current gross rate is greater than the rate cap life
    Assignment RATE_CAP_LIFE=CUR_GROSS_RATE
    Warning Rate Cap Life < Current Gross Interest Rate
    Error Level Info
  • Rule ID: 54
    Error Condition (RATE_CAP_LIFE < CUR_NET_RATE and RATE_CAP_LIFE <> 0)
    Error Description Current net rate is greater than the rate cap
    Assignment
    Warning Rate Cap Life < Current Net Interest Rate
    Error Level Info
  • Rule ID: 55
    Error Condition (RATE_CHG_MIN is NULL or RATE_CHG_MIN < 0)
    Error Description Minimum rate change cannot be negative
    Assignment RATE_CHG_MIN=0
    Warning Rate Change Minimum < 0
    Error Level Warning
  • Rule ID: 56
    Error Condition (RATE_DECR_CYCLE is NULL or RATE_DECR_CYCLE < 0)
    Error Description Rate decrease limit (cycle) must not be negative
    Assignment RATE_DECR_CYCLE=0
    Warning Rate Decrease Limit (Cycle) < 0
    Error Level Warning
  • Rule ID: 57
    Error Condition (RATE_FLOOR_LIFE > CUR_GROSS_RATE and CUR_GROSS_RATE <> 0 and TEASER_END_DATE < AS_OF_DATE)
    Error Description Current gross rate is less than the rate floor
    Assignment
    Warning Rate Floor Life > Currrent Gross Interest Rate
    Error Level Info
  • Rule ID: 58
    Error Condition (RATE_FLOOR_LIFE > CUR_NET_RATE)
    Error Description Rate floor life must not be greater than the current net rate
    Assignment RATE_FLOOR_LIFE=CUR_GROSS_RATE
    Warning Rate Floor Life > Currrent Net Interest Rate
    Error Level Info
  • Rule ID: 59
    Error Condition (RATE_INCR_CYCLE is NULL or RATE_INCR_CYCLE < 0)
    Error Description Rate increase limit (cycle) cannot be less than 0
    Assignment RATE_INCR_CYCLE=0
    Warning Rate Increase Limit (Cycle) < 0
    Error Level Warning
  • Rule ID: 60
    Error Condition (REMAIN_NO_PMTS is NULL or REMAIN_NO_PMTS < 1)
    Error Description There has to be at least 1 payment left
    Assignment REMAIN_NO_PMTS=1
    Warning Remaining Number of Payments < 1
    Error Level Warning
  • Rule ID: 61
    Error Condition (ADJUSTABLE_TYPE_CD > 0 and (RATE_SET_LAG is NULL or RATE_SET_LAG < 0))
    Error Description Rate set lag cannot be negative
    Assignment RATE_SET_LAG=0
    Warning Rate Set Lag < 0
    Error Level Warning
  • Rule ID: 62
    Error Condition (TEASER_END_DATE < ORIGINATION_DATE)
    Error Description Teaser End Date cannot be before Origination Date
    Assignment TEASER_END_DATE=ORIGINATION_DATE
    Warning Teaser End Date < Origination Date
    Error Level Warning
  • Rule ID: 63
    Error Condition (TEASER_END_DATE > MATURITY_DATE)
    Error Description Teaser End Date cannot be after Maturity Date
    Assignment TEASER_END_DATE=MATURITY_DATE
    Warning Teaser End Date > Maturity Date
    Error Level Warning
  • Rule ID: 64
    Error Condition (AMRT_TYPE_CD = 710 and ORG_PAR_BAL < CUR_PAR_BAL)
    Error Description Original balance on Rule of 78's instruments should be greater than current balance
    Assignment
    Warning Orginal Par Balance < Current Par Balance
    Error Level Info
  • Rule ID: 65
    Error Condition (AMRT_TYPE_CD = 600 and (REPRICE_FREQ is NULL or REPRICE_FREQ = 0))
    Error Description Reprice Frequency cannot be zero for Adjustable Negative Amortization instrument
    Assignment
    Warning Adjustable Negative Amortization instrument has Reprice Frequency = 0
    Error Level Info
  • Rule ID: 66
    Error Condition (REPRICE_FREQ <> 0 and LAST_REPRICE_DATE > NEXT_REPRICE_DATE)
    Error Description Last repricing date is greater than next repricing date
    Assignment LAST_REPRICE_DATE=(CASE REPRICE_FREQ_MULT WHEN 'Y' THEN ADD_MONTHS(NEXT_REPRICE_DATE, -REPRICE_FREQ*12) WHEN 'M' THEN ADD_MONTHS(NEXT_REPRICE_DATE, -REPRICE_FREQ) ELSE NEXT_REPRICE_DATE - REPRICE_FREQ END)
    Warning Last Reprice Date > Next Reprice Date
    Error Level Warning
  • Rule ID: 67
    Error Condition (ADJUSTABLE_TYPE_CD in (50, 250) and (INTEREST_RATE_CD is NULL or INTEREST_RATE_CD <= 0))
    Error Description Interest rate code must be valid for adjustable rate instruments
    Assignment ADJUSTABLE_TYPE_CD=0
    Warning Adjustable Rate instrument has invalid Interest Rate Code
    Error Level Warning
  • Rule ID: 68
    Error Condition (ADJUSTABLE_TYPE_CD > 0 and INTEREST_RATE_CD > 0 and exists (select 1 from fsi_ircs where fsi_ircs.interest_rate_cd = SOURCE_TABLE.interest_rate_cd and fsi_ircs.volatility_curve_flg > 0))
    Error Description Interest rate code of instrument is not an yield curve. Repricing attributes will be ignored and processed as fixed interest rate;
    Warning Invalid Interest Rate Code. Curve Type is not Interest Rate Curve
    Error Level Warning
  • Rule ID: 69
    Error Condition (NET_MARGIN_CD is NULL or NET_MARGIN_CD not in (0, 1))
    Error Description Valid net margin codes are 0 or 1.
    Assignment NET_MARGIN_CD=0
    Warning Invalid Net Margin Code
    Error Level Warning
  • Rule ID: 70
    Error Condition (AMRT_TYPE_CD = 600 and (NEG_AMRT_PMT_DECR_CYCLE is NULL or NEG_AMRT_PMT_DECR_CYCLE < 0))
    Error Description Payment Decrease Limit (Cycle) cannot be less than zero. Applicable to negative amortization instruments only
    Assignment NEG_AMRT_PMT_DECR_CYCLE=0
    Warning Negative Amortization Payment Decrease Limit (Cycle) = 0
    Error Level Warning
  • Rule ID: 71
    Error Condition (AMRT_TYPE_CD = 600 and (NEG_AMRT_PMT_DECR_LIFE is NULL or NEG_AMRT_PMT_DECR_LIFE < 0))
    Error Description Payment Decrease Limit (Life) cannot be less than zero. Applicable to negative amortization instruments only
    Assignment NEG_AMRT_PMT_DECR_LIFE=0
    Warning Negative Amortization Payment Decrease Limit (Life) = 0
    Error Level Warning
  • Rule ID: 72
    Error Condition (AMRT_TYPE_CD = 600 and NEG_AMRT_PMT_DECR_LIFE <> 0 and CUR_PAYMENT < ORG_PAYMENT_AMT * (1 - NEG_AMRT_PMT_DECR_LIFE/100))
    Error Description Current payment is less than the minimum payment amount. Applicable to negative amortization instruments only
    Assignment
    Warning Current Payment is less than Life Pay Floor
    Error Level Info
  • Rule ID: 73
    Error Condition (AMRT_TYPE_CD = 600 and (NEG_AMRT_PMT_INCR_LIFE is NULL or NEG_AMRT_PMT_INCR_LIFE < 0))
    Error Description Payment Increase Limit (Life) cannot be less than zero. Applicable to negative amortization instruments only
    Assignment NEG_AMRT_PMT_INCR_LIFE=0
    Warning Negative Amortization Payment Increase Limit (Life) = 0
    Error Level Warning
  • Rule ID: 74
    Error Condition (AMRT_TYPE_CD = 600 and NEG_AMRT_PMT_INCR_LIFE <> 0 and CUR_PAYMENT > ORG_PAYMENT_AMT * (1 + NEG_AMRT_PMT_INCR_LIFE/100))
    Error Description Current payment is greater than the maximum payment amount. Applicable to negative amortization instruments only
    Assignment
    Warning Current Payment is greater than Life Pay Cap
    Error Level Info
  • Rule ID: 75
    Error Condition (ISSUE_DATE > ORIGINATION_DATE)
    Error Description Issue date cannot be greater than origination date
    Assignment ISSUE_DATE=ORIGINATION_DATE
    Warning Issue Date > Origination Date
    Error Level Warning
  • Rule ID: 76
    Error Condition (REPRICE_FREQ is NULL or REPRICE_FREQ < 0)
    Error Description Repricing frequency must not be negative
    Assignment REPRICE_FREQ=0
    Warning Reprice Frequency < 0
    Error Level Warning
  • Rule ID: 77
    Error Condition (AMRT_TYPE_CD = 710 and REPRICE_FREQ <> 0)
    Error Description Rule of 78's instruments are implicitly fixed rate.
    Warning Amortization type is Rule of 78's but Reprice Frequency is not 0
    Error Level Warning
  • Rule ID: 78
    Error Condition (ORG_PAR_BAL = 0 and (REPRICE_FREQ is NULL or REPRICE_FREQ = 0))
    Error Description For transfer pricing of fixed rate instruments, the original balance should be populated.
    Assignment
    Warning Original Par Balance is 0 for a fixed rate instrument
    Error Level Info
  • Rule ID: 79
    Error Condition (REPRICE_FREQ <> 0 and TEASER_END_DATE > ORIGINATION_DATE and TEASER_END_DATE > AS_OF_DATE and NEXT_REPRICE_DATE > TEASER_END_DATE)
    Error Description Next repricing date is greater than teaser end date.
    Assignment NEXT_REPRICE_DATE=TEASER_END_DATE
    Warning Next Reprice Date > Teaser End Date
    Error Level Warning
  • Rule ID: 80
    Error Condition (ADJUSTABLE_TYPE_CD <> 0 and (LRD_BALANCE is NULL or LRD_BALANCE = 0))
    Error Description The balance as of the last repricing date cannot be equal to 0
    Assignment LRD_BALANCE=CUR_PAR_BAL
    Warning Balance on Last Reprice Date = 0
    Error Level Warning
  • Rule ID: 81
    Error Condition (ADJUSTABLE_TYPE_CD <> 0 and (LAST_REPRICE_DATE < ISSUE_DATE or LAST_REPRICE_DATE < ORIGINATION_DATE))
    Error Description Transfer pricing will not occur when the last repricing date is less than the issue date and origination date
    Assignment LAST_REPRICE_DATE=ORIGINATION_DATE
    Warning Last Reprice Date < Issue/Origination Date
    Error Level Info
  • Rule ID: 82
    Error Condition (ADJUSTABLE_TYPE_CD = 0 and REPRICE_FREQ > 0)
    Error Description Repricing frequency and adjustable type code are inconsistent
    Warning Reprice Frequency > 0 for fixed rate instrument
    Error Level Info
  • Rule ID: 83
    Error Condition (ADJUSTABLE_TYPE_CD <> 0 and (REPRICE_FREQ is NULL or REPRICE_FREQ = 0))
    Assignment
    Warning Adjustable Type is not fixed but Reprice Frequency is 0
    Error Level Info
  • Rule ID: 84
    Error Condition (AMRT_TYPE_CD = 710 and ADJUSTABLE_TYPE_CD <> 0)
    Error Description Rule of 78's instrument should only have a Fixed adjustable type code.
    Warning Amortization type is Rule of 78's but Adjustable Type is not fixed
    Error Level Warning
  • Rule ID: 85
    Error Condition (AMRT_TYPE_CD = 600 and ADJUSTABLE_TYPE_CD = 0)
    Error Description Negative amortization instruments cannot have fixed adjustable type code
    Assignment AMRT_TYPE_CD=100
    Warning Adjustable Type is fixed rate for Negative amortization instrument
    Error Level Info
  • Rule ID: 86
    Error Condition (LAST_INT_PAYMENT_DATE > NEXT_INT_PAYMENT_DATE and INT_PMT_FREQ > 0)
    Error Description Last interest payment date is greater than next interest payment date and can be calculated using interest payment frequency
    Assignment LAST_INT_PAYMENT_DATE=(CASE INT_PMT_FREQ_MULT WHEN 'Y' THEN ADD_MONTHS(NEXT_INT_PAYMENT_DATE, -INT_PMT_FREQ*12) WHEN 'M' THEN ADD_MONTHS(NEXT_INT_PAYMENT_DATE, -INT_PMT_FREQ) ELSE NEXT_INT_PAYMENT_DATE - INT_PMT_FREQ END)
    Warning
    Error Level Warning
  • Rule ID: 87
    Error Condition (LAST_INT_PAYMENT_DATE > NEXT_INT_PAYMENT_DATE and (INT_PMT_FREQ is NULL or INT_PMT_FREQ <= 0))
    Error Description Last interest payment date is greater than next interest payment date, but cannot be calculated using interest payment frequency.
    Assignment LAST_INT_PAYMENT_DATE=ORIGINATION_DATE
    Warning
    Error Level Warning
  • Rule ID: 88
    Error Condition (LAST_PRIN_PAYMENT_DATE > NEXT_PRIN_PAYMENT_DATE and PRIN_PMT_FREQ > 0)
    Error Description Last principal payment date is greater than next principal payment date and can be calculated using principal payment frequency
    Assignment LAST_PRIN_PAYMENT_DATE=(CASE PRIN_PMT_FREQ_MULT WHEN 'Y' THEN ADD_MONTHS(NEXT_PRIN_PAYMENT_DATE, -PRIN_PMT_FREQ*12) WHEN 'M' THEN ADD_MONTHS(NEXT_PRIN_PAYMENT_DATE, -PRIN_PMT_FREQ) ELSE NEXT_PRIN_PAYMENT_DATE - PRIN_PMT_FREQ END)
    Warning
    Error Level Warning
  • Rule ID: 89
    Error Condition (LAST_PRIN_PAYMENT_DATE > NEXT_PRIN_PAYMENT_DATE and (PRIN_PMT_FREQ is NULL or PRIN_PMT_FREQ <= 0))
    Error Description Last principal payment date is greater than next principal payment date, but cannot be calculated using principal payment frequency.
    Assignment LAST_PRIN_PAYMENT_DATE=ORIGINATION_DATE
    Warning Last principal payment date > Next principal payment date
    Error Level Warning
  • Rule ID: 90
    Error Condition (LAST_INT_PAYMENT_DATE < ORIGINATION_DATE)
    Error Description Last interest payment date cannot be less than the origination date
    Warning Last Interest Payment Date < Origination Date
    Error Level Warning
  • Rule ID: 91
    Error Condition (LAST_PRIN_PAYMENT_DATE < ORIGINATION_DATE)
    Error Description Last principal payment date cannot be less than the origination date
    Warning Last Principal Payment Date < Origination Date
    Error Level Warning
  • Rule ID: 92
    Error Condition (LAST_INT_PAYMENT_DATE > AS_OF_DATE and ORIGINATION_DATE <= AS_OF_DATE)
    Error Description Last interest payment date cannot be greater than the as-of-date if the instrument originated in the past.
    Assignment LAST_INT_PAYMENT_DATE=AS_OF_DATE
    Warning Last interest payment date > As of Date
    Error Level Warning
  • Rule ID: 93
    Error Condition (LAST_PRIN_PAYMENT_DATE > AS_OF_DATE and ORIGINATION_DATE <= AS_OF_DATE)
    Error Description Last principal payment date cannot be greater than the as-of-date if the instrument originated in the past.
    Assignment LAST_PRIN_PAYMENT_DATE=AS_OF_DATE
    Warning Last principal payment date > As of Date
    Error Level Warning
  • Rule ID: 94
    Error Condition (INTEREST_TIMING_TYPE_CD = 2 and AMRT_TYPE_CD in (100, 400, 600, 710, 800, 840, 850))
    Error Description Interest type can only be arrears for conventionally amortizing instruments.
    Assignment INTEREST_TIMING_TYPE_CD=1
    Warning Amortization Type is conventional but interest timing is Advance
    Error Level Warning
  • Rule ID: 95
    Error Condition (INTEREST_TIMING_TYPE_CD is NULL or INTEREST_TIMING_TYPE_CD not in (1, 2, 3))
    Error Description Interest type must be a valid OFSAA code.
    Warning Invalid interest timing type
    Error Level Warning
  • Rule ID: 96
    Error Condition (COMPOUND_BASIS_CD is NULL or COMPOUND_BASIS_CD not in (110, 120, 130, 140, 150, 160, 170))
    Error Description Compounding basis code must be a valid OFSAA code
    Assignment COMPOUND_BASIS_CD=160
    Warning Invalid Compounding Basis Code
    Error Level Warning
  • Rule ID: 97
    Error Condition (ACCRUAL_BASIS_CD IN (1, 4, 5) and (INT_PMT_FREQ_MULT = 'D' or AMRT_TYPE_CD in (800,801, 802)))
    Error Description Accrual basis code cannot have a 30 day month assumption on instruments defined by a payment schedule
    Assignment ACCRUAL_BASIS_CD=3
    Warning Amortization Type / Accrual Basis Error
    Error Level Warning
  • Rule ID: 98
    Error Condition (ACCRUAL_BASIS_CD = 7 and (HOLIDAY_CALENDAR_CODE is NULL or HOLIDAY_CALENDAR_CODE <=0 or HOLIDAY_CALC_OPTION_CD is NULL or HOLIDAY_CALC_OPTION_CD not in (1, 2) or HOLIDAY_ROLLING_CONVENTION_CD is NULL or HOLIDAY_ROLLING_CONVENTION_CD not in (2,3,4,5)))
    Error Description Holiday calendar must be give when using Business/252 accrual basis
    Assignment
    Warning Holiday calendar not given for B/252 accrual basis
    Error Level Info
  • Rule ID: 99
    Error Condition (AMRT_TYPE_CD = 10 and BEHAVIOUR_TYPE_CD is NULL)
    Error Description Behaviour Type Code is Null, defaulted to 1 (Non-Maturity)
    Assignment BEHAVIOUR_TYPE_CD=1
    Warning Behaviour Type Code is Null
    Error Level Warning
  • Rule ID: 100
    Error Condition (AMRT_TYPE_CD = 10 and BEHAVIOUR_TYPE_CD not in (1,2,3))
    Error Description Behaviour Type Code is invalid, defaulted to 1 (Non-Maturity)
    Warning Invalid Behaviour Type Code
    Error Level Warning
  • Rule ID: 101
    Error Condition (AMRT_TYPE_CD = 10 and BEHAVIOUR_TYPE_CD = 2 and (BEHAVIOUR_SUB_TYPE_CD is NULL or BEHAVIOUR_SUB_TYPE_CD not in (201, 202, 203)))
    Error Description Behaviour Sub Type should be 201 or 202 or 203 when Behaviour Type is Non-Performing
    Assignment BEHAVIOUR_SUB_TYPE_CD=201
    Warning Invalid Behavior Sub Type Code
    Error Level Warning
  • Rule ID: 102
    Error Condition (AMRT_TYPE_CD = 10 and BEHAVIOUR_TYPE_CD = 3 and (BEHAVIOUR_SUB_TYPE_CD is NULL or BEHAVIOUR_SUB_TYPE_CD not in (305, 306)))
    Error Description Behaviour Sub Type should be 305 or 306 when Behaviour Type is Devolvement and Recovery
    Assignment BEHAVIOUR_SUB_TYPE_CD=305
    Error Level Warning
  • Rule ID: 103
    Error Condition (AMRT_TYPE_CD = 840 and RESIDUAL_AMOUNT < 0)
    Error Description Residual Amount cannot be less than 0 for Lease instrument
    Assignment RESIDUAL_AMOUNT=0
    Warning Invalid Residual Amount for Lease instrument
    Error Level Warning
  • Rule ID: 104
    Error Condition (AMRT_TYPE_CD = 840 and RESIDUAL_AMOUNT > CUR_PAR_BAL)
    Error Description Residual Amount cannot be higher than Current Par Balance for Lease instrument
    Error Level Warning
  • Rule ID: 105
    Error Condition (AMRT_TYPE_CD = 850 and MATURITY_AMOUNT > 0 and ADJUSTABLE_TYPE_CD > 0)
    Error Description Annuity instrument with maturity amount must have fixed interest rate
    Warning Invalid Adjustable Type for Annuity with Maturity Amount
    Error Level Warning
  • Rule ID: 106
    Error Condition (MOA_EXPECTED_BAL > 0 and (MOA_OFFSET_PERCENT is NULL or MOA_OFFSET_PERCENT < 0))
    Error Description Expected balance is greater than 0 but offset percentage is less than 0
    Assignment MOA_OFFSET_PERCENT=0
    Warning Invalid offset percent
    Error Level Warning
  • Rule ID: 107
    Error Condition ((MOA_EXPECTED_BAL * MOA_OFFSET_PERCENT/100) > CUR_PAR_BAL)
    Error Description Calculated Offset Balance is higher than Current Par Balance
    Assignment
    Warning Calculated Offset Balance > Current Par Balance
    Error Level Info
  • Rule ID: 108
    Error Condition (ADJUSTABLE_TYPE_CD = 10 and (REPRICE_PATTERN_CD is NULL or REPRICE_PATTERN_CD <= 0))
    Error Description Invalid reprice pattern code given for instrument
    Warning Invalid reprice pattern code
    Error Level Warning
  • Rule ID: 109
    Error Condition (ADJUSTABLE_TYPE_CD = 10 and REPRICE_PATTERN_CD > 0 and REPRICE_PATTERN_CD not in (select ADJUSTABLE_TYPE_CD from fsi_reprice_pattern))
    Error Level Warning
  • Rule ID: 110
    Error Condition (ADJUSTABLE_TYPE_CD = 0 and (ORG_PAYMENT_AMT is NULL or ORG_PAYMENT_AMT <= 0))
    Error Description Original payment amount is required for fixed-rate instruments
    Assignment ORG_PAYMENT_AMT=CUR_PAYMENT
    Warning Invalid Original Payment Amount
    Error Level Warning
  • Rule ID: 111
    Error Condition (PERCENT_SOLD < 0 or PERCENT_SOLD > 99)
    Error Description Percent Sold must be greater than or equal to zero and less than 100
    Assignment PERCENT_SOLD=0
    Warning Invalid Percent Sold
    Error Level Warning
  • Rule ID: 112
    Error Condition (CUR_PAR_BAL is NULL or CUR_PAR_BAL = 0)
    Error Description Instruments with Current Par Balance zero are not processed.
    Assignment
    Warning Current Par Balance = 0
    Error Level Warning
  • Rule ID: 113
    Error Condition (EMBEDDED_OPTIONS_FLG = 1 and AMRT_TYPE_CD <> 700)
    Error Description Embedded option is supported only for non-amortizing instrument
    Assignment EMBEDDED_OPTIONS_FLG=0
    Warning Invalid embedded options flag
    Error Level Warning
  • Rule ID: 114
    Error Condition (ADJUSTABLE_TYPE_CD = 0 and TP_EFFECTIVE_DATE > ORIGINATION_DATE)
    Error Description TP Effective Date must not be after Origination Date for fixed rate instrument
    Assignment
    Warning Invalid TP Effective Date
    Error Level Info
  • Rule ID: 115
    Error Condition (ADJUSTABLE_TYPE_CD = 0 and TP_EFFECTIVE_DATE < ORIGINATION_DATE)
    Error Description TP Effective Date must not be before Origination Date for fixed rate instrument
    Assignment
    Error Level Info
  • Rule ID: 116
    Error Condition (ADJUSTABLE_TYPE_CD > 0 and TP_EFFECTIVE_DATE > LAST_REPRICE_DATE)
    Error Description TP Effective Date must not be after Last Reprice Date for non-fixed rate instrument
    Assignment
    Error Level Info
  • Rule ID: 117
    Error Condition (ADJUSTABLE_TYPE_CD > 0 and TP_EFFECTIVE_DATE <= NEXT_REPRICE_DATE)
    Error Description TP Effective Date must not equal to Next Reprice Date for non-fixed rate instrument
    Assignment
    Error Level Info
  • Rule ID: 118
    Error Condition (TP_EFFECTIVE_DATE is not NULL and TP_EFFECTIVE_DATE < '01-JAN-1970')
    Error Description TP Effective Date is before '01-JAN-1970'
    Assignment TP_EFFECTIVE_DATE=ORIGINATION_DATE
    Error Level Info
  • Rule ID: 119
    Error Condition (TP_EFFECTIVE_DATE > MATURITY_DATE)
    Error Description TP Effective Date is after maturity date
    Error Level Info
  • Rule ID: 120
    Error Condition (ADJUSTABLE_TYPE_CD = 0 and ADJ_EFFECTIVE_DATE > ORIGINATION_DATE)
    Error Description Adjustment Effective Date must not be after Origination Date for fixed rate instrument
    Assignment
    Warning Invalid Adjustment Effective Date
    Error Level Info
  • Rule ID: 121
    Error Condition (ADJUSTABLE_TYPE_CD = 0 and ADJ_EFFECTIVE_DATE < ORIGINATION_DATE)
    Error Description Adjustment Effective Date must not be before Origination Date for fixed rate instrument
    Assignment
    Error Level Info
  • Rule ID: 122
    Error Condition (ADJUSTABLE_TYPE_CD > 0 and ADJ_EFFECTIVE_DATE > LAST_REPRICE_DATE)
    Error Description Adjustment Effective Date must not be after Last Reprice Date for non-fixed rate instrument
    Assignment
    Error Level Info
  • Rule ID: 123
    Error Condition (ADJUSTABLE_TYPE_CD > 0 and ADJ_EFFECTIVE_DATE <= NEXT_REPRICE_DATE)
    Error Description Adjustment Effective Date must not equal to Next Reprice Date for non-fixed rate instrument
    Assignment
    Error Level Info
  • Rule ID: 124
    Error Condition (ADJ_EFFECTIVE_DATE is not NULL and ADJ_EFFECTIVE_DATE < '01-JAN-1970')
    Error Description Adjustment Effective Date is before '01-JAN-1970'
    Assignment ADJ_EFFECTIVE_DATE=ORIGINATION_DATE
    Error Level Info
  • Rule ID: 125
    Error Condition (ADJ_EFFECTIVE_DATE > MATURITY_DATE)
    Error Description Adjustment Effective Date is after maturity date
    Error Level Info
  • Rule ID: 10001
    Error Condition (OPTION_RFR_IRC_CD > 0 and exists (select 1 from fsi_ircs where fsi_ircs.RISK_FREE_RATE_FLG is null or fsi_ircs.RISK_FREE_RATE_FLG = 0 and fsi_ircs.INTEREST_RATE_CD=SOURCE_TABLE.OPTION_RFR_IRC_CD))
    Error Description Risk Free Interest Rate Curve is not defined as Risk-Free.
    Assignment
    Warning Invalid Risk Free Interest Rate Curve
    Error Level Error
  • Rule ID: 10002
    Error Condition (OPTION_RFR_IRC_CD > 0 and exists (select 1 from fsi_ircs where fsi_ircs.ISO_CURRENCY_CD != SOURCE_TABLE.ISO_CURRENCY_CD and fsi_ircs.INTEREST_RATE_CD=SOURCE_TABLE.OPTION_RFR_IRC_CD))
    Error Description Currency of risk free Interest Rate Curve is different from currency of instrument record.
    Assignment
    Error Level Error
  • Rule ID: 10003
    Error Condition (OPTION_VOL_IRC_CD > 0 and exists (select 1 from FSI_VOL_SURFACE_MASTER where FSI_VOL_SURFACE_MASTER.ISO_CURRENCY_CD != SOURCE_TABLE.ISO_CURRENCY_CD and FSI_VOL_SURFACE_MASTER.VOL_SURFACE_SYS_ID=SOURCE_TABLE.OPTION_VOL_IRC_CD))
    Error Description Currency of Volatility Surface is different from currency of instrument record.
    Assignment
    Warning Invalid Volatility Surface
    Error Level Error
  • Rule ID: 10004
    Error Condition (EMBEDDED_OPTIONS_FLG = 1 and STRIKE_TYPE_CD not in (1,2))
    Error Description Strike Type must be Rate or Price for instruments with embedded options.
    Assignment
    Warning Invalid Strike Type for Embedded Option
    Error Level Error
  • Rule ID: 10005
    Error Condition (EMBEDDED_OPTIONS_FLG = 1 and EXERCISE_TYPE_CD not in (1,2,3))
    Error Description Exercise type for instrument with embedded options must be American, Bermudan or European.
    Assignment
    Warning Invalid Exercise Type for Embedded Option
    Error Level Error
  • Rule ID: 10006
    Error Condition (EMBEDDED_OPTIONS_FLG = 1 and EXERCISE_TYPE_CD = 1 and OPTION_START_DATE <= AS_OF_DATE)
    Error Description Option Start Date for an American option must be after As of Date.
    Assignment
    Warning Invalid Option Start Date for American Option
    Error Level Info
  • Rule ID: 10007
    Error Condition (EMBEDDED_OPTIONS_FLG = 1 and OPTION_TYPE_CD not in (1,2))
    Error Description Option Type must be Call or Put for instrument with Embedded Option.
    Assignment
    Warning Invalid Option Type for Embedded Option
    Error Level Error
  • Rule ID: 10008
    Error Condition (EMBEDDED_OPTIONS_FLG = 1 and STRIKE_TYPE_CD = 2 and nvl(STRIKE_IRC_CD,0) < 1)
    Error Description Strike type is Rate for instrument with Embedded Option but Strike Interest Rate Curve is not available.
    Assignment
    Warning Invalid Strike Interest Rate Curve for Embedded Option
    Error Level Error
  • Rule ID: 10009
    Error Condition (EMBEDDED_OPTIONS_FLG = 1 and STRIKE_TYPE_CD = 2 and nvl(RATE_LOOKUP_CD,0) not in (1,2,3,4))
    Error Description Strike type is Rate for instrument with Embedded Option but Rate Lookup Code is not available.
    Assignment
    Warning Invalid Rate Lookup Code for Embedded Option
    Error Level Error
  • Rule ID: 10010
    Error Condition (EXCHG_OF_PRINCIPAL is NULL OR EXCHG_OF_PRINCIPAL not in (0,1))
    Error Description Invalid Exchange of Principal flag
    Assignment - Default Value 1
    Warning Invalid Exchange of Principal flag.
    Error Level Warning
  • Rule ID: 10011
    Error Condition (ACCOUNT_TYPE in (150, 200, 350, 400, 610, 620) and AMRT_TYPE_CD not in (10, 820, 801, 700, 802))
    Error Description Invalid Amortization Type.
    Assignment
    Warning Invalid Amortization Type for non earning assets and liabilities
    Error Level Warning
  • Rule ID: 10012
    Error Condition (ACCOUNT_TYPE in (150, 200, 350, 400, 610, 620) and (CUR_NET_RATE <> 0 or CUR_GROSS_RATE <> 0))
    Error Description Interest Rate of non earning assets and liabilities must be 0.
    Assignment
    Warning Invalid Interest Rate for non earning assets and liabilities
    Error Level Warning
  • Rule ID: 10013
    Error Condition (ACCOUNT_TYPE in (150, 200, 350, 400, 610, 620) and ADJUSTABLE_TYPE_CD <> 0)
    Error Description Adjustable Type of non earning assets and liabilities must be 0.
    Assignment
    Warning Invalid Adjustable Type for non earning assets and liabilities
    Error Level Warning
  • Rule ID: 10014
    Error Condition (ACCOUNT_TYPE in (150, 200, 350, 400, 610, 620) and INTEREST_TIMING_TYPE_CD <> 1)
    Error Description Interest timing type of non earning assets and liabilities must be Arrears.
    Assignment
    Warning Invalid Interest timing type for non earning assets and liabilities
    Error Level Warning
  • Rule ID: 10015
    Error Condition (ADJUSTABLE_TYPE_CD in (50, 250) and not exists (select 1 from fsi_ircs where fsi_ircs.interest_rate_cd = SOURCE_TABLE.interest_rate_cd and nvl(fsi_ircs.volatility_curve_flg,0) = 0))
    Error Description Interest rate code of instrument does not exist. Repricing attributes will be ignored and processed as fixed interest rate.
    Assignment
    Warning Wrong Interest Rate Code for adjustable rate instrument
    Error Level Warning
  • Rule ID: 10016
    Error Condition (ORG_INT_PAYMENT_DATE is NULL OR ORG_INT_PAYMENT_DATE < ORIGINATION_DATE)
    Error Description Invalid Original Interest Payment Date
    Assignment
    Warning Invalid Original Interest Payment Date
    Error Level Warning
  • Rule ID: 10017
    Error Condition (ORG_PRIN_PAYMENT_DATE is NULL OR ORG_INT_PAYMENT_DATE < ORIGINATION_DATE)
    Error Description Invalid Original Principal Payment Date
    Assignment
    Warning Invalid Original Principal Payment Date
    Error Level Warning
  • Rule ID: 10018
    Error Condition (ADJUSTABLE_TYPE_CD = 300 and AMRT_TYPE_CD in (600, 850, 840))
    Error Description Amortization Type of Tiered Rate Account must not be negative amortization, annuity, and lease
    Assignment
    Warning Tiered rate functionality does not apply to negative amortization, annuity, and lease amortization types
    Error Level Warning
  • Rule ID: 10019
    Error Condition (ADJUSTABLE_TYPE_CD = 300 and nvl(INTEREST_TIMING_TYPE_CD,1) != 1)
    Error Description Interest Timing Type of Tiered Rate Account must be Interest in Arrears
    Assignment
    Warning Interest Timing Type of Tiered Rate Account cannot be Interest in Advance or Set in Arrears
    Error Level Warning
  • Rule ID: 10020
    Error Condition (ADJUSTABLE_TYPE_CD NOT IN (0, 50, 250))
    Error Description Adjustable Type of tiers must be Fixed, Floating or Other Adjustable
    Assignment
    Warning Adjustable Type of tier must be Fixed, Floating or Other Adjustable
    Error Level Warning
  • Rule ID: 10021
    Error Condition (ADJUSTABLE_TYPE_CD = 300 and EXISTS (select 1 from FSI_D_ACCOUNT_RATE_TIERS WHERE FSI_D_ACCOUNT_RATE_TIERS.ID_NUMBER=SOURCE_TABLE.ID_NUMBER AND FSI_D_ACCOUNT_RATE_TIERS.IDENTITY_CODE = SOURCE_TABLE.IDENTITY_CODE AND (select SUM(CUR_PAR_BAL) from FSI_D_ACCOUNT_RATE_TIERS WHERE FSI_D_ACCOUNT_RATE_TIERS.ID_NUMBER=SOURCE_TABLE.ID_NUMBER AND FSI_D_ACCOUNT_RATE_TIERS.IDENTITY_CODE = SOURCE_TABLE.IDENTITY_CODE) != SOURCE_TABLE.CUR_PAR_BAL))
    Error Description Tiered Rate Accounts Current Par Balance mismatch
    Assignment
    Warning Sum of CUR_PAR_BAL of tiers is different from CUR_PAR_BAL of account
    Error Level Info
  • Rule ID: 10022
    Error Condition (ADJUSTABLE_TYPE_CD = 300 and EXISTS (select 1 from FSI_D_ACCOUNT_RATE_TIERS WHERE FSI_D_ACCOUNT_RATE_TIERS.ID_NUMBER=SOURCE_TABLE.ID_NUMBER AND FSI_D_ACCOUNT_RATE_TIERS.IDENTITY_CODE = SOURCE_TABLE.IDENTITY_CODE AND (select SUM(ORG_PAR_BAL) from FSI_D_ACCOUNT_RATE_TIERS WHERE FSI_D_ACCOUNT_RATE_TIERS.ID_NUMBER=SOURCE_TABLE.ID_NUMBER AND FSI_D_ACCOUNT_RATE_TIERS.IDENTITY_CODE = SOURCE_TABLE.IDENTITY_CODE) != SOURCE_TABLE.ORG_PAR_BAL))
    Error Description Tiered Rate Accounts Original Par Balance mismatch
    Assignment
    Warning Sum of ORG_PAR_BAL of tiers is different from ORG_PAR_BAL of account
    Error Level Info
  • Rule ID: 10023
    Error Condition (ADJUSTABLE_TYPE_CD IN (50, 250) AND (INTEREST_RATE_CD is NULL or INTEREST_RATE_CD <= 0))
    Error Description Adjustable Rate tier has invalid Interest Rate Code
    Assignment
    Warning Interest rate code must be valid for adjustable rate tiers
    Error Level Warning
  • Rule ID: 10024
    Error Condition (ADJUSTABLE_TYPE_CD IN (50, 250) AND (NEXT_REPRICE_DATE is NULL or NEXT_REPRICE_DATE <= AS_OF_DATE) AND REPRICE_FREQ > 0)
    Error Description Adjustable Rate tier has invalid Next Reprice Date
    Assignment
    Warning Next Reprice Date must be valid for adjustable rate tiers
    Error Level Warning
  • Rule ID: 10025
    Error Condition (ADJUSTABLE_TYPE_CD IN (50, 250) AND (REPRICE_FREQ_MULT is NULL or REPRICE_FREQ_MULT not in ('D','M','Y')))
    Error Description Adjustable Rate tier has invalid Reprice Frequency Multiplier
    Assignment
    Warning Repricing Frequency Multiplier must be D, M, or Y for adjustable rate tiers
    Error Level Warning
  • Rule ID: 10026
    Error Condition (ADJUSTABLE_TYPE_CD IN (50, 250) AND (REPRICE_FREQ is NULL or REPRICE_FREQ <= 0))
    Assignment
    Warning Repricing Frequency must not be negative for adjustable rate tiers
    Error Level Warning
  • Rule ID: 10027
    Error Condition (ADJUSTABLE_TYPE_CD = 300 and NOT EXISTS (select 1 from FSI_D_ACCOUNT_RATE_TIERS WHERE FSI_D_ACCOUNT_RATE_TIERS.ID_NUMBER=SOURCE_TABLE.ID_NUMBER AND FSI_D_ACCOUNT_RATE_TIERS.IDENTITY_CODE = SOURCE_TABLE.IDENTITY_CODE ))
    Error Description Rate tier details of account is not available
    Assignment
    Warning Adjustable Type of account is Tiered Rate but data of Account Rate Tiers is not available
    Error Level Warning
