2.3.1 Defining Forecast Balances Using Node Level Assumptions
Node Level Assumptions allow you to define assumptions at any level of the Multi Dimensional Balance Sheet Structure (MDBSS) hierarchy. The MDBSS supports a hierarchical representation of your chart of accounts, so you can take advantage of the parent-child relationships defined for the various nodes of your MDBSS hierarchies while defining rules. Children of parent nodes on an MDBSS automatically inherit the assumptions defined for the parent nodes. However, assumptions directly defined for a child take precedence over those at the parent level.
Prerequisites
Performing basic steps for creating or editing a Forecast Balance Rule.
Procedure
To define Forecast Balance, follow these steps:
  1. Navigate to Forecast Balance page.
  2. Select Forecast Balance Method. Based on the selected Method, Forecast Balance page will be displayed.
    • New Add
      Figure 2-6 Forecast Balance-New Add
      • Enter Balance values for Buckets.
      • Click Apply.
      You can also use the Excel Export feature to download the data in Excel format.
    • Target Average
      Figure 2-7 Forecast Balance- Average
      Forecast Balance-Target Average
      • Click Apply.
    • Target End
      Figure 2-8 Forecast Balance-Target End
      • Click Apply.
    • Target Growth Percent
      Figure 2-9 Forecast Balance-Target Growth Percent
      • Click Apply.
    • Rollover
      Figure 2-10 Forecast Balance-Rollover
      • Click Create button to select a Target node. The Hierarchy page will appear.
      • Select the MDBSS node for the rollover and click Ok.
        You can use Search functionality to search a MDBSS node. The searched node will display in Search Results tab.
      • The selected MDBSS node(s) will appear in Select Target and Assign Categories section.
        Figure 2-11 Forecast Balance-Rollover
      • Select the desired runoff type (Total, Prepay, Maturity, Payment, Core, Volatile, Devolvement, Recovery, or NPA).
      • Click Apply to navigate to Define Time Buckets and Percentages section.
      • Define the input bucket ranges. You only need to define multiple bucket ranges if you want to vary rollover assumptions by modeling buckets. The bucket ranges defined here only apply to rollover occurring from the source leaf to the target leaf. You must have at least one bucket range defined. Typically, you define a bucket range from the first modeling bucket to the last modeling bucket, covering the entire modeling horizon. To define a bucket range, perform below steps:
        • Add Time Bucket using Add icon. Default bucket is 1 and you cannot delete this.
        • Select a Time Bucket. Based on selected Time Bucket, start bucket date and end bucket date will display.
          Figure 2-12 Forecast Balance-Rollover
        • Continue adding time buckets until all desired ranges have been defined. Expand the Time Bucket to add percentage.
      • In Enter the percentage rollover for the given Target.
      • Click Apply.
    • Rollover with New Add
      Figure 2-13 Forecast Balance-Rollover with New Add
      • Select the MDBSS node for the rollover with New Add and click Ok.
      • The selected MDBSS node(s) will appear in Select Target and Assign Runoff Categories section.
        Figure 2-14 Forecast Balance-Rollover with New Add
      • Define the input bucket ranges. You only need to define multiple bucket ranges if you want to vary rollover assumptions by modeling buckets. The bucket ranges defined here only apply to rollover occurring from the source leaf to the target leaf. You must have at least one bucket range defined. Typically, you define a bucket range from the first modeling bucket to the last modeling bucket, covering the entire modeling horizon. The default Bucket Range includes all modeling buckets. To forecast new business in a subset of the modeling horizon, reduce the bucket range by increasing the bucket start date or decreasing the bucket end date. As you change the bucket start and/or the bucket end, the view adjusts accordingly to display only buckets within the selected range. To define a bucket range, perform below steps:
          Figure 2-15 Forecast Balance-Rollover with New Add
      • Enter the percentage rollover for the given Target.
      • Click Apply to navigate to Define New Volume Details section.
        Figure 2-16 Forecast Balance-Rollover with New Add
      • The New Volume Detail section is used to input new volume assumptions. In this section, you can select the range of modeling buckets and input balance or percentage assumptions for each modeling bucket within this bucket range. Enter the targeted value.
      • Click Apply.
    • Rollover with Growth%
      Figure 2-17 Forecast Balance-Rollover with Growth%
        Figure 2-18 Forecast Balance-Rollover with Growth%
        Figure 2-19 Forecast Balance-Rollover with Growth%
      • Define the bucket ranges. You only need to define multiple bucket ranges if you want to vary rollover assumptions by modeling buckets. The bucket ranges defined here only apply to rollover occurring from the source leaf to the target leaf. You must have at least one bucket range defined. Typically, you define a bucket range from the first modeling bucket to the last modeling bucket, covering the entire modeling horizon. The default Bucket Range includes all modeling buckets. To forecast new business in a subset of the modeling horizon, reduce the bucket range by increasing the bucket start date or decreasing the bucket end date. As you change the bucket start and/or the bucket end, the view adjusts accordingly to display only buckets within the selected range. To define a bucket range, perform below steps:
        Figure 2-20 Forecast Balance-Rollover with Growth%
      • The New Volume Detail section is used to input new volume assumptions. In this section, you can select the range of modeling buckets and input balance or percentage assumptions for each modeling bucket within this bucket range. Select corresponding row to the first modeling bucket. If rate-volume relationships are used, this cell also corresponds to the first rate tier. Enter the targeted value.
      • Click Apply.
