2 Non Maturity Products Model Analysis
Non-Maturity Products Modeling helps you to understand the relation between market and bank rate, how much is core out of total available balance for the portfolio, and how long core will remain with the bank based on Decay Rate Profile.
Table 2-1 User Role and Privileges
Purpose Role Code Role Name Function Code Function Name
NMP Data Generation RLNMDADMIN Non Maturity Model Data Generation Admin Role NMDATAADD Add Non Maturity Model Data Creation Process
NMDATARUN Run Non Maturity Model Data Creation Process
NMDATADEL Delete Non Maturity Model Data Creation Process
NMDATAEDIT Edit Non Maturity Model Data Creation Process
NMDATACOPY Copy Non Maturity Model Data Creation Process
NMDATAVIEW View Non Maturity Model Data Creation Process
RLNMDANALYST Non Maturity Model Data Generation Analyst Role NMDATAADD Add Non Maturity Model Data Creation Process
RLNMDAUDIT Non Maturity Model Data Generation Auditor Role NMDATAVIEW View Non Maturity Model Data Creation Process
NMP Model Analysis RLNMDLADMIN Non Maturity Model Analysis Admin Role NMMODELADD Add Non Maturity Model Analysis
NMMODELDELETE Delete Non Maturity Model Analysis
NMMODELEDIT Edit Non Maturity Model Analysis
NMMODELCOPY Copy Non Maturity Model Analysis
NMMODELVIEW View Non Maturity Model Analysis
RLNMDLANALYST Non Maturity Model Analysis Analyst Role NMMODELADD Add Non Maturity Model Analysis
RLNMDLAUDIT Non Maturity Model Analysis Auditor Role NMMODELVIEW View Non Maturity Model Analysis
Non-Maturity Products Model Analysis Summary
This page is the gateway to all Non-Maturity Products Model Analysis rules and related functionality. You can navigate to other pages relating to Non-Maturity Products Model Analysis rules from this point.
Figure 2-1 Non-Maturity Products Model Analysis Summary Page
Search Non-Maturity Products Model Analysis Rule
Prerequisites: Predefined Non-Maturity Products Model Analysis rule
To search for a Non-Maturity Products Model Analysis rule, follow these steps:
Click Search after entering the search criteria. The search results are displayed in a table containing all the Non-Maturity Products Model Analysis rules that meet the search criteria.
Or
The other method to search a Non-Maturity Products Model Analysis rule is using the Field Search option. The Field Search is an inline wildcard UI search that allows you to enter value partially or fully and the rows that match the entered string in any of its column is fetched in the Summary table. Enter the Name, Status, Folder, or Access Type status of the Non-Maturity Products Model Analysis rule and click Search.
  • Add: Click the Add icon on the page header to build a new Non-Maturity Products Model Analysis rule.
  • Actions: Click Actions to refresh page or see help.
  • Delete: Enables you to select and delete one or multiple rules in the table simultaneously.
  • Pin/Unpin: Enables you to pin or unpin the selected rule
  • Export: Allows you to download the summary page details in .cs format.
  • Columns: Enables you to customize the list of columns.
The Non-Maturity Products Model Analysis summary table displays the following columns:
  • Model Analysis Name: Name of the Non-Maturity Products Model Analysis rule's short name. Click Model Analysis Name link to view the details of Non-Maturity Products Model Analysis rule.
  • Status: Status of the Non-Maturity Products Model Analysis rule.
  • Folder: The folder where the Non-Maturity Products Model Analysis rule is saved.
  • Currency: Displays the Currency for which Non-Maturity Products Model Analysis Rule is defined. One rule can be created only on one particular currency.
  • Created On: The Date and Time when the Non-Maturity Products Model Analysis rule was created.
  • Created By: The user who created the Non-Maturity Products Model Analysis rule.
  • Last Modified By: The user who modified run the Non-Maturity Products Model Analysis rule.
  • Last Modified Date: The Date and Time when the Non-Maturity Products Model Analysis rule was last modified.
  • Action: Click this icon to view a list of actions that you can perform on the Non-Maturity Products Model Analysis rule.
    • View/Edit: Based on the user privilege assigned, you can either only view or edit existing Non-Maturity Products Model Analysis rules. To edit a rule, you must have Read/Write privilege.
    • Save As: You can reuse a Non-Maturity Products Model Analysis rule by saving it under a new name thus saving time and effort in entering data multiple times; it also leads to reduced data entry errors.
    • Delete: You can delete Non-Maturity Products Model Analysis rules that you no longer require. Note that only Non-Maturity Products Model Analysis rule owners and those with Read/Write privileges can delete Non-Maturity Products Model Analysis rules. A Non-Maturity Products Model Analysis rule that has a dependency cannot be deleted. A rule cannot be retrieved after deletion.
