10.2.3.1 Running Hybrid Rate Generation using Simplified Batch
To run Hybrid Rate Generation using Simplified Batch, follow these steps:
  1. Navigate to Common Object Maintenance, select Operations, and then select Simplified Batch.
    (Optional) <Enter a step example.>
  2. Click Add.
  3. From the Task Details pane, click Select Task. In the Task Selection window, select Task Type as Transform Data. Click Search. In the Task Selector, select the IRC_HYBRID_SCHEDULER and click Ok.
  4. Enter the Parameters and click Save.
  5. In the Simplified Batch Summary page, search the Hybrid Rate Generation batch, and select it. Click the Run icon.
  6. Click Yes to confirm you want to continue, enter a date (this will be your TO DATE), and click Ok to continue. A confirmation message is displayed.
  7. Click Ok. When the batch is complete, navigate to Operations and select View Log to view the processing log.
    Any error messages or warnings are accessible from the View Log window.
    Simplified Batch does not provide access to logs for Transform Data tasks.
    For more information, see the OFS Analytical Applications Infrastructure User Guide.
