- Liquidity Risk Regulatory Calculations for European Banking Authority User Guide
- Liquidity Coverage Ratio Calculation as Per Delegated Act
- Calculation of Contractually Required Collateral
- Calculating Excess Collateral
- Calculating Net Derivative Cash Inflows and Outflows
- Cash Flow Netting at Derivative Contract Level
4.4.3.4.1 Cash Flow Netting at Derivative Contract Level
Cash flows from each derivative contract are netted as follows:
- When cash inflows and outflows are denominated in the same currency and occur at the same time bucket:
- The cash inflows and outflows are summed up and the net value is computed as follows:
Figure 3-22 Net Cash Flow
- When net cash flow is positive and there is no netting agreement associated with the derivative contract, the value is treated as net derivative cash outflow.
- If the net cash flow is negative and there is no netting agreement associated with the derivative contract, the value is treated as net derivative cash inflow.
- When cash inflows and outflows are denominated in different currencies but settle within the same day:
- The cash inflows and outflows are summed up after being converted to the reporting currency and the net value is computed.
- If the Net Cash Flow is positive and there is no netting agreement associated with the derivative contract, the value is treated as net derivative cash outflow.
- If the Net Cash Flow is negative and there is no netting agreement associated with the derivative contract, the value is treated as net derivative cash inflow.
- When Cash Inflows and Outflows are denominated in different currencies and do not settle within the same day:
- The cash outflows from each derivative contract without an associated netting agreement are summed up and treated as net derivative cash outflows.
- The cash inflows from each derivative contract without an associated netting agreement are summed up and treated as net derivative cash inflow.
If a derivative contract has a netting agreement associated with it, the cash flow is further netted across contracts at the netting agreement level.
