Create Paragraphs
The paragraph should be added after the start widget paragraph. Navigate to Notebook page to create the paragraphs.
The following types of paragraph creation are supported for model creation:
  • Python Paragraph
  • Shell in Python Paragraph
  • Conda Paragraph
  • PGQL Paragraph
  • PGX - Java Paragraph
  • Paragraph
  • PGX - Python Paragraph
  • PGX – Algorithm Paragraph
  • PGX - PySpark Paragraph
  • MySQL Paragraph
  • Markdown Paragraph
To create Paragraphs in the Model Studio Notebooks:
  1. Open the draft in Pipeline Designer and click Notebook tab.
  2. Hover your mouse above or below a paragraph to display the interpreter toolbar.
    Figure 11-110 Interpreter toolbar
    This image displays the Interpreter toolbar.
  3. Click an icon in the toolbar to select an interpreter and add a new paragraph that uses that interpreter. When you click some of the icons, the paragraph that's created includes example code that you can run.
    You should not delete the start widget paragraph or rewrite the contents of this seeded paragraph.
