Editing Pipeline Descriptions
You can edit the description and search tags for user-created pipelines.
Pre-configured pipelines cannot be edited. You can only edit user-configure pipelines
To edit the description and search tags, follow these steps:
  1. Navigate to the DTP Pipeline Designer page.
  2. Click the Action button Action iconcorresponding to the pipeline that you want to copy.
  3. Click Edit Edit icon. The Edit Pipeline pane displays.
  4. Modify the required details.
    Table 13-7 Fields for Editing Pipelines and their Descriptions
    Field Description
    Name Displays the name of the pipeline that you want to edit. You cannot modify this field.
    Pipeline Focus Displays the focus for the pipeline that you want to edit. This will be the focus for the new pipeline. You cannot modify this field.
    Search Tags Add or remove keywords for the pipeline. These keywords can be used as search tags while searching for a pipeline. Search tags are also used to group pipelines of the same type. These search tags appear as filters in the dashboard.
    Description Edit the description for the pipeline.
  5. Click Save.
