Managing Threshold Sets (MMG)
FCCM Cloud Service uses tunable Thresholds to change variable values for scenarios.
When scenarios are created, thresholds are established. You can use the Threshold Editor to modify threshold values of scenarios, and create and edit threshold sets to fine-tune how that scenario finds matches, without changing the values defined at the data set or pattern level. These thresholds are applied to scenarios to find matches. Using this tool, you can enter a new value for a threshold (within a defined range) or reset the thresholds to their sample values.
Threshold sets allow you to run the same scenario multiple times against a variety of sources (for example, currencies, or jurisdictions) with separate threshold values for each source.
Changing threshold values can generate significantly more or fewer alerts, depending upon the modifications made.
