Model Report
This option allows you to view the Model report and download the same in PDF format.
To view and download Report, follow these steps:
  1. Open a Model in Pipeline Designer.
  2. Click Generate Model Report.
    The Model Report window is displayed.
    The function, Model Report View-All, is mapped by default to the role,MMGMDLRPTREAD, and the groups MDLREV, MDLAPPR, and MDLUSR. If this function is unmapped, then the Generate Model Report button will be disabled. You must map this function to enable the Generate Model Report option.
  3. Select the parameters to generate the report.
  4. Click Preview Report.
    The report is displayed based on selected parameters.
  5. Click Export as PDF to save the report as PDF in local system.
