Publish Data Studio
After creating the Draft Models, publish the Notebooks, which have the Model script.
To create a Scoring Model:
  1. Create a Draft Model. See the Create Draft Models section for more information.
  2. Click next to corresponding Draft Model and select Publish Data Studio option.
    The Publish Model window is displayed.
    Figure 11-116 Publish Model
    This image displays the Publish Model.
  3. Enter the details as shown in the following table.
    Table 11-29 Field and its description for the Publish popup window
    Field or Icon Description
    Model Name The field displays the name of the Model. Modify the name if required.
    Model Description The field displays the description for the Model. Enter or modify the description if required.
    Technique Enter the registered technique to use.
    Run Version Select a run version.
    Script
    The table displays the Paragraphs created in the Training Model. Select the Paragraphs that you want to use to create the Scoring Model.
    Track Output - Select this to track the output of the paragraph.
  4. Click Publish.
