View Simulator Conditions
You can view Simulator Conditions using the Threshold Manager.
To view simulator conditions for a threshold set, follow these steps:
  1. In the Navigation List menuNavigation List iconclick Business Processes, then Data Transformation Pipeline.
  2. Select DTP Threshold Manager. The All Threshold Sets page displays.
  3. In the All Thresholds page, select the check box corresponding to the threshold set you want to view simulation details for.
  4. Click Simulation History Simulation History icon. The Simulation Details for this threshold set opens as a new tab.
  5. Click the Simulation Run ID for the simulation you want to view conditions for. The View Threshold Set pop-up window displays the details of this threshold set.
    If you want to make modifications to these conditions, click Edit & Simulate . The Edit Threshold Set pop-up window displays. Follow the steps in Edit Simulator Conditions to make these changes.
