Using the Calendar Widget
The Calendar widget allows you to designate and configure the calendar for the scenario's look back and frequency periods.
Before adding or configuring a calendar, you must first have created the pipeline.
  1. In the Pipeline Designer page, select the pipeline you want to add or modify the calendar for. The Pipeline Canvas displays.
  2. Right-click on the Canvas to display the list of widgets. Select Calendar Calendar widget. The Calendar widget is added to the pipeline Canvas. You can drag and drop the widget within the Canvas as needed.
  3. Click Options Options iconthen click Edit Edit icon. The Calendar pane displays.
  4. Provide the details as described in the following table.
    Table 14-9 Fields for Creating Calendars and their Descriptions
    Field Description
    Name Enter the name for the calendar. This field allows only the following characters: A-Z a-z 0-9 '_' For example, Abc_123 or Abc 123
    Lookback Type Select the Lookback Type used in this pipeline using the drop-down list. This is the range of days of data monitored in each run of the detection process. Options include Days or Months. This controls the unit in which both the lookback period and frequency period are expressed.
    Days Select either Calendar Days or Business Days from the drop-down list.
    Weekdays Select all the days which should be considered Week Days from the list.
    Holiday Master Select the applicable holidays which should be considered in this calendar. This section is populated by the data provided in the FCC_AM_HOLIDAY_MASTER table. For more about how this table is populated, see AMLHolidayMasterDataLoad Batch Details.
  5. Click Save. A confirmation message displays.
