PreviousNext
JavaScript must be enabled to correctly display this content
8.2.2 Create a Conda Environment
To create a Conda environment:
Click Conda Environments to navigate to
Environment Summary page from any other window in the
application.
This page displays the Conda environments in a table.
Click the Create link in the Creation Status column of a desired environment to create the Conda environment, or, you can also click the Action icon adjacent to a desired environment and then click Create. Note that this option is only available if the status in the Creation Status column is Create.
The Create option is not displayed for the Conda environment with the creation status Inspect.
A confirmation dialog is displayed.
Click Create.
The Conda environment is created.
These environments can be selected while creating a Workspace.
For more details, see the Workspace Schema section.
In addition, these environments can be selected during the Model
pipeline execution.
