8.4 Kafka Topics
Kafka is a distributed data source which is used to create real-time data pipelines and allows you to decouple data streams and systems.
Click Kafka Topics icon to navigate to Kafka Topics page from any other window in the application. You can configure and manage Kafka topics and clusters from this page.
Figure 8-25 API Summary page
The following table provides descriptions for the fields and icons on the Kafka Topicspage.
Table 8-4 Fields and icons on the Sandbox Summary page
| Field or Icon | Description |
| Search | The field to search for a Kafka
topics and clusters.
Enter specific terms in the field for which you want to search, and press Enter on the keyboard to display the results. |
| Topic Name | The topic name of the Kafka. |
| Cluster Name | The cluster name of the Kafka. |
| Description | The description of the Kafka. |
| Created Date | The date on which the API was created. |
| Kafka Clusters | Click Kafka Clusters to view/create/delete Kafka Clusters. |
| Register API | Click Register API to create a new Kafka topic. |
| Action | Click the three dots to perform View/Edit/Delete functions on selected Kafka topic. |
