11.2 Model Libraries
The Model Library information is used to bind a particular technique and its details to one unique Model Library. The Starting point for the Model builder is to register a model library with the application after it is properly set up in the python environment to be used.
Currently, the following libraries are supported:
  • keras
  • ONNX
  • scikit-learn
  • xgboost
As an example, the following section provides information on how to set up and register the scikit-learn library.
Setting up the Python Library in the python environment:
Open the terminal and install the scikit-learn library using the following command:
python3 -m pip install scikit-learn
Proxy might be required to install the packages from pip.
Once the installation is complete, check for the package details using the following command:
pip show scikit-learn
Once the installation is complete in Python environment, you need to register the library into the application.
Registering the Python Library
  1. In the Mega menu, click Modeling > Model Libraries.
    The Library Summary page is displayed.
    Figure 11-38 Library Summary page
    This image displays the Library Summary page.
  2. In the Library Summary page, click Add.
    The Add Library page is displayed.
    Figure 11-39 Add Library page
    This image displays the Add Library page.
  3. Enter the name of the library.
  4. Enter the version and description of the library.
  5. Enter the signatures such as Import, Load, Train, Save, and Infer. For more details on the signatures, click the respective help icons.
    Some of the signatures captured in library stage might not be standard across different algorithm/techniques provided by the library.
  6. Click Create.
    The Model Objective is created and displayed in the Model Objective screen.
The User must check the details provided above from the home page of the library being captured.
For example: https://scikit-learn.org/stable/.
OR
You can select the Use Template option to pre-fill the entries from the seeded list of Libraries. Currently, the following libraries are present in the template.
Figure 11-40 Use Template
This image displays the Use Template.
You can also edit the data based on your requirements.
The .whl file for MMG-Python is available in the below location:
OFS_MMG/mmg-service/python-lib/mmg-8.1.3.2.0-py3-none-any.whl
This can be installed using the command Python3 -m pip install MMG-8.1.3.2.0-py3-none-any.whl
On successfull installation, the user will get a message: "Successfully installed MMG-8.1.3.2.0".
