11.5.13.4 SS $RUNSK support for processing Delta Data by Data Pipeline and Match Rules
A new parameter to pass RUNSK is being implemented in the Scheduler UI.
Dynamic Parameters screen for new batches are created.
  1. RUNSKEY will be present in Task Parameters while copying task for existing batches.
  2. RUNSKEY should be visible in View Execution Parameters - Task Parameters in Monitor screen.
  3. RUNSKEY will change just as BatchRunID in "Rerun" Case.
  4. RUNSKEY will remain same just as BatchRunID in "Restart" Case.
  5. RUNSKEY will be stored for batches in "AAICL_SS_BATCH_RUN" in column "N_RUNSKEY".
