8.2.10 Using the .condarc Conda Configuration File
Overview
The Conda configuration file, .condarc, is an optional runtime configuration file that allows advanced users to configure various aspects of Conda, such as which channels it searches for; packages, proxy settings, and environment directories.
A .condarc file can also be used in an administrator-controlled installation to override the users’ configuration. See Administering a multi-user Conda Installation.
The .condarc file can change many parameters, including:
  • Where Conda looks for packages.
  • If and how Conda uses a proxy server.
  • Where Conda lists known environments.
  • Whether to update the Bash prompt with the currently activated environment name.
  • Whether user-built packages should be uploaded to Anaconda.org.
  • What default packages or features to include in new environments.
Creating and Editing
The .condarc file is not included by default, but it is automatically created in your home directory the first time you run the conda config command. To create or modify a .condarc file, open a terminal and enter the conda config command. The .condarc configuration file follows a simple YAML syntax.
Example:
conda config --add channels conda-forge
Alternatively, you can open a text editor such as Notepad on Windows, or TextEdit on MacOS, or VS Code. Name the new file .condarc and save it to your user home directory or root directory. To edit the .condarc file, open it from your home or root directory and edit it in the same way you would with any other text file. If the .condarc file is in the root environment, it will override any in the Home Directory.
You can find information about your .condarc file by typing Conda info in your terminal. This will give you information about your .condarc file, including where it is located.
You can also download a sample .condarc file to edit in your editor and save to your user Home Directory or Root Directory.
Example:
To set the auto_update_conda option to False run:
conda config --set auto_update_conda False
For a complete list of Conda Config commands, see the command reference. The same list is available at the terminal by running conda config --help. You can also see the Conda Channel Configuration for more information.
Conda supports a wide range of configuration options. This section gives a non-exhaustive list of the most frequently used options and their usage. For a complete list of all available options for your version of conda, use the conda config --describe command.
Searching for .condarc
Conda looks in the following locations for a .condarc file:
  • XDG_CONFIG_HOME is the path to where the user-specific configuration files should be stored or defined by following the XDG Base Directory Specification (XDGBDS).
  • Default to $HOME/.config must be used. CONDA_ROOT is the path for your base conda installation.
  • CONDA_PREFIX is the path to the current active environment.
  • CONDARC must be a path to a file named .condarc, condarc, or end with a YAML suffix (.yml or .yaml).
Any condarc files that exist in any of these special search path directories need to end in a valid yaml extension (.yml or .yaml).
Channels
You can create or configure the .condarc file (the global configuration file for Conda) by using the following example:
channels:
- conda-forge
- defaults
channel_alias: https://oracle.repo
default_channels:
- https://oracle.repo
ssl_verify: False
proxy_servers:
http: http://www-proxy.us.oracle.com:80
https: http://www-proxy.us.oracle.com:80
Channel Locations
When you list the channel locations in the .condarc file, it overrides the Conda defaults that in turn cause Conda to only search the listed channels in a given order.
To automatically include all default channels, use defaults. Non-URL channels are interpreted as an Anaconda.org user or as per the organization names. Perform the steps documented in the Set a channel alias (channel_alias) to modify the channel_alias. The default is defaults.
Example
channels:
- <anaconda_dot_org_username>
- http://some.custom/channel
- file:///some/local/directory
- defaults
Add a .condarc file in the root directory of the environment (or when you are using conda config, use the --env option) to select channels for a single environment. For example, you have installed Miniconda with Python 3 in your home directory and the environment is named newenvironment, the path may be:
~/miniconda3/envs/newenvironment/.condarc
Default channels (default_channels)
The defaults channel points to several channels in the repo.anaconda.com repository, but a new list of default channels are set if the default_channels is defined. This is especially useful for airgapped and enterprise installations:
Setting both the channel_alias and default_channels by an administrator, ensures that all users only pull packages from an on-premises repository, for example:
default_channels:
Conflict Merging Strategy
When conflicts between configurations arise, the following strategies are employed:
  • Lists-merge
  • Dictionaries-merge
  • Primitive-clobber
Precedence
The precedence by which the Conda configuration is built is shown in this. Each new arrow takes precedence over the ones before it. For example, config files (by parse order) will be superseded by any of the other configuration options. Configuration environment variables (formatted as CONDA_<CONFIG NAME>) will always take precedence over the other 3.
Obtaining Information from the .condarc file
You can use the following commands to get the effective settings for conda. The effective settings are those that have merged settings from all the sources mentioned above.
To get all keys and their values:
conda config --get
To get the value of a specific key, such as channels:
conda config --get channels
To show all the configuration file sources and their contents:
conda config --show-sources
Saving Settings to your .condarc file
The .condarc file can also be modified via conda commands. The following are several examples of how to do this.
To add a new value, such as http://conda.anaconda.org/mutirri, to a specific key, such as channels:
conda config --add channels http://conda.anaconda.org/mutirri
To remove an existing value, such as http://conda.anaconda.org/mutirri from a specific key, such as channels:
conda config --remove channels http://conda.anaconda.org/mutirri
To remove a key, such as channels, and all of its values:
conda config --remove-key channels
To configure channels and their priority for a single environment, make a .condarc file in the root directory of that environment.
Sample .condarc file
Because the .condarc file is just a YAML file, it means that it can be edited directly. Below is an example .condarc file:
