4.4.2.1 Java Settings
To configure the Java Settings, refer the following table:
Table 4-2 Java Settings
Description | Example Value |
In the Ensure that SYMBOLIC links to JAVA installation are not set in the PATH variable. |
Note: OFS MMG does not support OpenJDK. |
In the .profile file, set JAVA_BIN to include
the JDK absolute path.
For example: JAVA_BIN
