Java Settings
To configure the Java Settings, refer the following table:
Table 4-2 Java Settings
Description Example Value
In the .profile file, set the Java tool options for all versions JDK 11.0.20 and above updates.
Ensure that SYMBOLIC links to JAVA installation are not set in the PATH variable.
JAVA_TOOL_OPTIONS=" -Djdk.util.zip.disableZip64ExtraFieldValidation=true"
export JAVA_TOOL_OPTIONS
OFS MMG does not support OpenJDK.
In the .profile file, set JAVA_BIN to include the JDK absolute path.
For example: JAVA_BIN =/usr/java/jdk-11.0.20/bin
export JAVA_BIN
