9.7 Updating Wallet Aliases for Oracle Schemas
It is recommended to use the same wallet aliases used in the base environment.
In case if the same wallet aliases cannot be used, perform the following:
  1. Update the MMG Config Schema Wallet Alias values in config.sh file present in the following path: OFS_MMG/bin with configured corresponding values of the cloned environment.
  2. Replace the placeholders and update the wallet alias for Workspace Schemas or other Oracle datasources using the following command:
    update MMG_DB_MASTER set V_PROPERTY_VALUE = ‘##WALLET_ALIAS##’ where V_PROPERTY_NAME = ‘WALLET_ALIAS’ and V_DB_NAME = ‘##DATASOURCE NAME##’
