PreviousNext
JavaScript must be enabled to correctly display this content
Create Objective (Folders)
Create folders called Objectives within which you can create Models.
To create an Objective, follow these steps:
Click Launch Workspace next to corresponding Workspace
to Launch Workspace to display the MMG Dashboard window
with application configuration and model creation menu.
Click Model Pipelines to display the Model
Pipelines window.
The window displays folders that contain models and model records
in a table.
Click Add and select Objective
from the list to display the Objective Details dialog
box.
Figure 10-56 Select Objective from
Add
Enter details in Objective Name and
Description fields in the Add
Objective dialog box.
