Execution History
This section of Pipeline Designer shows the history of the executed pipelines.
Figure 10-81 Execution History tab
You can compare and refresh the executions by clicking on Compareand Refresh icons.
To view the inputs, output, and canvas view, click on the corresponding options in the table.
Clicking Output icon displays the Output Details page, where you can view "Executed-only" paragraph outputs. By default, this option is enabled, you can disable this option based on your requirements.
By default, Tracked option is selected that displays outputs tracked from the time of the execution. Select All option to view all the outputs.
