Model Actions
The Model Actions window allows you to view the list of models for which the Workflow action has been taken which requires review or approve across the workspace.
For example, when any Model User sends and Model for review or approval, the user receives the bulk Models in Model Actions window for review or approval. This helps when lot of models are received for review before deployment or some actions need to be performed on many models, such as making multiple models champion locally or globally, and so on.
  1. Click Launch Workspace next to corresponding Workspace to Launch Workspace to display the MMG Dashboard window with application configuration and model creation menu.
  2. Click Model Actions to view the list models pending an action such as approval.
    Figure 12-8 Review Models screen
    This image displays the Review Models screen.
    If you are a reviewer, Review Models screen is displayed and if you are an approver, Approve Models screen is displayed. This can be toggled in the header of the screen using Reviewer and Approver icon.
  3. To review the model, follow these steps:
    1. Select the Model using the corresponding check box and click Review.
    2. Enter Comments, if any, and click Review.
    Figure 12-9 Review Models window
    This image displays the Review Models window.
  4. To approve or reject the models, follow these steps:
    1. Select the Model using the corresponding check box and click Approve or Reject.
    2. Enter the comments in Comments field of the Approve Models window or Reject Models window and click Approve or Reject.
    Figure 12-10 Approve Models screen
    This image displays the Approve Models screen.
