Model Objective
Model Objective is the top level metadata where further models are created or trained which can be consumed in the upcoming steps.
Ensure Data Studio is up and running. A validation message is displayed when the Data Studio is down during creation of Model Objectives.
To add a Model Objective:
  1. Click Launch Workspace next to corresponding Workspace to Launch Workspace to display the MMG Dashboard window with application configuration and model creation menu.
  2. In the LHS menu, click Model Catalog to display the Model Objective Summary window.
    This window displays the model objectives in a table.
    The following table provides descriptions for the fields and icons on the Model Objective Summarypage.
    Table 10-14 Fields and icons on the Model Objective Summary page
    Field or Icon Description
    Search
    The field to search for Model Objectives.
    Enter specific terms in the field for which you want to search, and press Enter on the keyboard to display the results.
    Code The unique identifier of the Model Objective.
    Name The name of the Model Objective.
    Dataset The dataset which is used to create the Model Objective.
    Target Variable Target Variable is the important parameter after the dataset. During the dataset selection, target variable is selected that constitutes of number of columns/features.
    Type The type which is selected during model objective creation. The type can be either Classification or Regression.
    Action Click the three dots to perform View/Delete functions on the selected model objective..
