Creating the Application Configuration Schema
Ensure that you create an Oracle user to create the application configuration schema. For more details, see Creating an Oracle User section.
Assign the Grants
This section discusses the various grants required for the Oracle Database User.
Assign the following grants:
grant create SESSION to <oracle_database_user>;
grant create PROCEDURE to <oracle_database_user>;
grant create SEQUENCE to <oracle_database_user>;
grant create TABLE to <oracle_database_user>;
grant create TRIGGER to <oracle_database_user>;
grant create VIEW to <oracle_database_user>;
grant create MATERIALIZED VIEW to
grant select on SYS.V_$PARAMETER to
grant create SYNONYM to <oracle_database_user>;
grant select on sys.v_$parameter to
grant select on sys.dba_free_space to
grant select on sys.dba_tables to
grant select on sys.Dba_tab_columns to
grant create RULE to <oracle_database_user>;
grant create any trigger to
grant drop any trigger to <oracle_database_user>;
grant select on SYS.DBA_RECYCLEBIN to
This is required for the configuration schema and the workspace schema.
