Installing RODBC Library
- For ORD 3.6.1
- curl- O https://cran.r-project.org/src/contrib/Archive/RODBC/RODBC_1.3-16.tar.gz
- R CMD INSTALL RODBC_1.3-16.tar.gz
It needs write permission to‘/usr/lib64/R/library’
or similar root directory for system installation.
- For R 4.1.2
- curl- O https://cran.r-project.org/src/contrib/RODBC_1.3-19.tar.gz
- R CMD INSTALL RODBC_1.3-19.tar.gz
LD_LIBRARY_PATH
should contain path to$ORACLE_HOME/lib
and check that file ‘libsqora.so.19.1’ exists in$ORACLE_HOME/lib
. Now, set an environment variable namedRODBC_DRIVER
with value ‘libsqora.so.19.1’ whichever is present in$ORACLE_HOME/lib/
directory based on the Oracle Client Version Installation.Now for RODBC Connection to work for Sandbox, check the
TNS_ADMIN
path set, and then intnsnames.ora
, add the connection string details with alias as Sandbox Name. For example, if Sandbox Name is SAND1 for which the datasource is on host abc.in.oracle.com , port 1234 and service name – ABCXYZ, then intnsnames.ora
file add the following entry-SAND1 =
(DESCRIPTION =
(ADDRESS_LIST =
(ADDRESS = (PROTOCOL =
TCP)(HOST=abc.in.oracle.com)(PORT=1234))
(CONNECT_DATA =
(SERVICE_NAME = ABCXYZ)
If this only does not resolve the connections, then configure
odbcinst.ini. / odbc.ini
files as well as mentioned in Oracle Client Installation and Setup (figured by: > odbcinst -j)
