Model Techniques/ Model Library
Following are the prerequisites to use the model techniques from the older version when you upgrade to 8.1.2.4.0 version.
MMG_TECHNIQUE_MASTER table had no V_WORKSPACE_ID column, which has been added in this release and then the primary key is updated to (V_TECHNIQUE_ID, V_WORKSPACE_ID).
To use the existing Techniques in the upgraded setup, perform the below:
The V_WORKSPACE_ID column will have the value set as ##WORKSPACE## for the existing records by default. If the same records has to be used in the latest version of MMG, you must update the table MMG_TECHNIQUE_MASTER with relevant Workspace ID.
