ORD-3.6.1 Installation
To install ORD-3.6.1, follow the steps mentioned in the below guides:
  1. Check installation:
    1. R-version
  2. Installing other packages:
    Set proxy:
    1. R-e "install.packages('Rserve', repos='https://www.rforge.net/')"
    2. R-e "install.packages(c('knitr', 'ggplot2', 'backports'), repos='https://mirror.las.iastate.edu/CRAN/')"
