Setting up the Environment for Hive Data Sourcing
This section is applicable if you want to use Hive Data Source.
In the MMG Home directory, a lib folder is available for the Hive specific jars and a conf folder is available for the Kerberos configuration and Keytab files.
Hive source connection requirements
MMG_HOME/conf : kbank.keytab and krb5.conf files
MMG_HOME/lib : hive-jdbc-uber-2.6.3.0-235.jar
The datastudio placement of jars are for creating a connection from python lib and the other is from java for data sourcing.Configure the Hive jars and configuration files.
For Hadoop version 3.1.1 and hive version 3.1.2, below is the list of jar files that
needs to be copied into the OFS_MMG/lib location
zookeeper-3.4.9.jar
woodstox-core-5.0.3.jar
stax2-api-3.1.4.jar
slf4j-log4j12-1.7.25.jar
slf4j-api-1.7.25.jar
re2j-1.1.jar
log4j-1.2.17.jar
libthrift-0.9.3.jar
libfb303-0.9.3.jar
httpcore-4.4.4.jar
httpclient-4.5.2.jar
htrace-core4-4.1.0-incubating.jar
hive-service-3.1.2.jar
hive-metastore-3.1.2.jar
hive-jdbc-3.1.2.jar
hive-exec-3.1.2.jar
hadoop-hdfs-client-3.1.1.jar
hadoop-common-3.1.1.jar
hadoop-auth-3.1.1.jar
curator-client-2.12.0.jar
commons-logging-1.0.4.jar
commons-io-2.4.jar
commons-configuration2-2.1.1.jar
commons-collections-3.2.2.jar
commons-cli-1.2.jar
The mmg-service requires a restart after copying the Hive jars and configuration files. For more information, see the MMG User Guide.
