Verify the Connectivity of the Wallet
To verify the connectivity of the wallet, follow these steps:
  1. Test the connectivity using the following command:
    The ORACLE_HOME used with the wallet must be the same version or higher than the wallet created.
    $ export WALLET_LOCATION=<wallet_location>
    $ export TNS_ADMIN=<tnsnames.ora_location>. If you have created a new tnsnames.ora file, provide the location of the new file.
    $ sqlplus /@<alias_name>
The output is similar to:
SQL*Plus: Release 11
Connected to:
Oracle Database 12c
To verify if you are connected to the correct user:
SQL> show user
USER is "<database-user-name>"
