A APIs for Model Pipelines
All the listed APIs/Functions can be utilized by users in Model Pipelines.
Table A-1 Python Paragraph Scripting
API Type Functionality Prerequisite Notebook Execution Script Notebook Script Input Minimum Supported Version
Set User Set the user for a session
%python
from mmg.constants import *
user = "SAUSER"
set_user(user)
user - username to be set 8.1.1
Get User Get the user that has been set Set User
%python
get_user()
8.1.1
Attach Workspace Attach the workspace for a session
%python
from mmg.workspace import attach_workspace
workspace = "CS"
attach_workspace(workspace)
workspace- workspace to be attached 8.1.1
Get Workspace Get the workspace that has been attached Attach Workspace
%python
from mmg.workspace import get_workspace
get_workspace()
8.1.1
List Workspaces Lists all workspaces available to a user Set User
%python
from mmg.workspace import list_workspaces
list_workspaces()
8.1.1
Check AIF Check if AIF is set or not Set User
%python
from mmg.workspace import check_aif
check_aif()
8.1.1
List All Data Sources List all data sources available in a workspace for a set user. The default workspace chosen is the one that is attached. Set User, Attach Workspace
%python
from mmg.workspace import list_datasources
list_datasources(order=None)
order - None ensures that all the data sources will be listed for the attached workspace 8.1.1
List All Data Sources of Workspace List all Data Sources of a specific Workspace that is not the attached workspace for a set user. Set User
%python
workspace="HELLO NEW"
list_datasources(workspace,order=None)
workspace - Name of workspace for which data sources should be listed
order - None ensures that ALL data sources will be listed for that workspace
8.1.1
Fetch First Order Data Source This method will fetch the data source related to attached workspace with default order 1. Set User, Attach Workspace
%python
list_datasources()
order - 1
by default, if not specified
8.1.1
Fetch First Order Data Source of Workspace This method will fetch the data source with default order 1 related to specified workspace. Set User
%python
workspace="CS"
list_datasources(workspace)
workspace - Name of workspace for which data source should be listed
order- 1 by default if not specified
8.1.1
Fetch Nth Order Data Source This method will fetch the data source related to attached workspace with given order Set User, Attach Workspace
%python
list_datasources(order=2)
order - Order of data source to be fetched 8.1.1
Fetch Nth Order Data Source of Workspace This method will fetch the data source with given order related to specified workspace. Set User
%python
workspace="CS"
list_datasources(workspace,order=2)
order = Order of data source to be fetched
8.1.1
Get Connection Object Returns an Oracle DB / SQLAlchemy connection object for the data source of order 1 in the attached workspace.
Python:
from mmg.workspace import get_conn
conn = get_conn()
# conn = get_conn(conn_type=None)
import oracledb
if not isinstance(conn, oracledb.Connection):
print("Not Conn Object")
print(conn)
If conn_type is None or oracledb (or not specified), the API returns an oracledb.Connection by default. If conn_type="sqlalchemy", the API creates a connection object by using create_engine() from SQLAlchemy.
8.1.2.0
Get Connection Object To Specific Data Source Returns an Oracle DB / SQLAlchemy connection object to the specified data source (by name). Set User
Python:
datasource = "DS"
conn = get_conn(datasource, conn_type=None)
import oracledb
print(conn)
datasource = Name of the datasource for which the connection object must be returned.
datasource - Name of datasource for which the connection object has to be returned 8.1.2.0
Get Connection Object To Data Source Using Order Returns an Oracle DB / SQLAlchemy connection object to the data source of the specified order in the attached workspace. Set User, Attach Workspace
Python:
datasource = 2
import oracledb
print(conn)
datasource = Order number of the datasource in the attached workspace for which the connection object must be returned.
datasource - Order number of datasource in attached workspace for which the connection object has to be returned 8.1.2.0
Test Connection Object This script can be used to test the connection object to data source
OR
OR
%python
query="SELECT table_name FROM user_tables"
cur = conn.cursor()
cur.execute(query)
print(cur.fetchall())
if cur:
cur.close()
8.1.2.0
Table A-2 PYTHON LINEPARSER APIs (for MMG version 8.1.0)
API Type Functionality Notebook Execution Script Note
%python
mmg.attachWorkspace(workspace)
#eg- mmg.attachWorkspace("CS")
workspace - workspace to be attached (String)
Sets 'mmg' python variable which contains the information about the attached workspace.
Output- Print a boolean in one line on the status of workspace attachment and another line of boolean on status of AIF enabled and attached.
%python
mmg.listWorkspaces()
Sets 'ofs_wsList' python variable which is the list of all available workspaces.
Output- Print the list of workspaces.
%python
print(aif__isAttached)
Output- Boolean on the status of AIF.
Get Connection Object Returns cx_Oracle Connection Object
%python
mmg.getConnection(schema_name)
#eg- mmg.getConnection("OFSAA")
schema_name = name of the schema for which connection is required (String).
Sets 'conn' python variable which is the cx_Oracle connection object to be used for firing queries.
Publish Fetch and sets the Notebook JSON dump
%python
mmg.publish()
Sets 'emf_para' python variable which is the JSON dump for the notebook component.
Output- Print the set 'emf_para' value.
Register Register the Notebook
%python
mmg.register(register)
#eg- mmg.register({"modelname":"model1",\
# "modeldescription":"Model description"})
#eg- mmg.register(emf_para) {After doing mmg.publish()}
register - JSON Stringify object for RegisterNotebookBean Object.
Sets 'publishedNotebookId' python variable which is the studio notebook id for the published version.
Output- Prints the published notebook id.
Load Flat File
%python
mmg.loadFlatFile()
#eg- mmg.loadFlatFile()
Incomplete
Profile Data
%python
mmg.profileData(code,title)
#eg- mmg.profileData(ABC,XYZ)
