Delete Cached Dataset
A Cached Dataset can be deleted by using the API below where tag refers to a particular snapshot/timestamp of the dataframe.
Table 11-8 Delete Cached Dataset
API | Notebook Script | Notes/Input |
Delete Dataset |
from mmg.datasets import delete_df delete_df(dscode, tag) |
dscode = dataset code - string tag = tag with which the dataset was cached - string |
