10.1.2.5.2.1 Edit a Batch Group
The Edit Batch Group option allows you to edit the Batch Group details such as Batch Group name, Added Batches, and Batch Group Description.
To modify a Batch Group, perform the following steps:
  1. In the Define Batch window, click Batch Group option to list the batch groups.
  2. Click Edit corresponding to the Batch Group you want to modify.
    The Edit Batch window is displayed.
  3. Modify the required Batch Group details.
    For more information, see Create a Batch Group section.
  4. Click Save.
    The edited batch group is saved and displayed in the Define Batch window.
