Edit Dynamic Parameters
Dynamic Parameters facilitate modification of dynamic parameters for the batch. You can change the param value and save the changes to the batch. The Edit Dynamic Parameters option is available in all the tab in the Schedule Batch window.
To edit the dynamic parameters for a batch/batch group:
  1. In the Schedule Batch window, click Edit Dynamic Parameters.
  2. In the Edit Dynamic Params window, modify the values as required.
  3. Use the SYSDATE-x option to reference relative dates execute or schedule a batch. In the Edit Dynamic Parameter window, enter a value, for example; SYSDATE-2, to represent two days before the execution date/time. You must ensure that the value for x is a non-negative integer
  4. Click Save.
    The modified parameters are applied to the Batch.
