7 Workspaces
Use the Dashboard to create and manage workspaces. By default, a Sample workspace is created which you can provision and use it to understand the workspace workflow.
Workspaces can be in the production environment (deployed), or they can exist in a separate instance on their own (on local for testing purposes) with a copy of data that comes from the desired data source (production or external data source).
You can view the following details on Workspace Summary page:
  • Number of Sandbox Workspaces
  • Number of Production Workspaces
  • File Manager
    File manager is a ftpshare home path. It has option to Upload a new file., create a new folder, preview the file, delete and download options.
    For File Manager to be visible on Workspace Summary, File Read, File Write, and File Delete roles must be mapped.
The Workspace Dashboard allows you to view the models of the launched workspace. To access the Dashboard window, follow these steps:
  1. Navigate to Workspace Summary page.
    The page displays workspace records in a tile format.
  2. Click next to corresponding Workspace to Launch Workspace.
    The Dashboard window is displayed with application configuration and model creation menu.
    The Workspace Dashboard shows the following details of a launched workspace:
    • Mega Menu
    • Recently Used
    • Most Used Tags
    • Models Status
    • Job Status
    • Models Timeline
Figure 7-1 Workspace Dashboard
This image displays the Workspace Dashboard.
