9.5.2 Access Model Pipelines
- Navigate to Workspace Summarypage.The page displays workspace records in a table.
- Click Launch next to corresponding Workspace to Launch
Workspace.The Dashboard window is displayed with application configuration and model creation menu.
- In the LHS menu, click Model Pipelines to display the
Model Pipelines page. The window displays objectives that contain drafts and models. When you hover on the count that are next to the ID column, it displays the count of sub objectives, Drafts, Models, and Champion if available.
Figure 9-54 Model Pipelines page
You can switch the Model Summary page view from Flat to Hierarchical and vice-versa. Flat list is the default view in Production workspace while Hierarchical list is the default in Sandboxes.
- Hierarchical option: The Model Management window shows the hierarchical list of the Objectives using the Hierarchical option. In the Hierarchy view, you can see the following details of the Objectives such as Objective Name, and ID.
- Flat option: The Model Pipeline
window shows the flat list of all the models (published and drafts)
using the Flat option. Flat list is not
objective-specific. It shows the models across all the objectives. You
can search the models using the Filter by Version, Filter by Status, and
All champions. You can also sort the drafts and models by Default or
Latest first options.
- In the Flat list of models, you can see the
following details of the models such as Name, ID, Version,
Objective ID, Objective Name, Owner, and Status.
Figure 9-55 Model Pipelines
The following table provides descriptions for the fields and icons on the Model Pipeline page.Table 9-15 Fields and icons on the Model Pipeline page
Field or Icon Description Model Pipeline Page Header The header that follows the global header in the application. Breadcrumbs Indicates the position of the current page in the Model Management hierarchy. Use breadcrumbs locator links to navigate back to higher levels in the hierarchy after you have drilled down through levels of functions. Click to navigate to Model Summary page.
Click or to navigate back to Workspace Summary page.
Create Objectives and Models Select Add to display a list with the following options: - Draft
- Objective
- Seeded Models
However, if you want to know about the cycle of model creation, see the Create, Review, Approve, and Deploy a Model Section.
Requester Displays that the logged-in user has the Requester privileges when the status is green. You can create a model. However, to approve and publish, the model must be reviewed by a user with reviewer privileges and approved by a user with approver privileges.
Reviewer Displays that the logged-in user has the Reviewer privileges when the status is green. You can review models. However, to approve and publish, the model must be approved by a user with approver privileges.
Approver Displays that the logged-in user has the Approver privileges when the status is green. You can approve models that are created and reviewed.
Model Pipeline Page Table The table displays the objective and model records on the page. Objective Name Displays the name and description of the Objective ID Displays the ID of the objective. Owner Displays the owner who created the Drafts. This information does not display for an Objective.
Tags Displays the tags associated with the Models or Drafts. This information does not display for an Objective.
Delete Objective Select to delete the model from the Confirmation dialog box. Click Delete to process or click Cancel to cancel. This information does not display for an Objective.
Edit Objective Select to edit the models in Data Studio. See the Edit Models section for more information. This information does not display for an Objective.
