10.1.6.1 Batch Group
Batch Group is a process of grouping the batches that are required to be execute together for execution of the Date and time-based background tasks based on a defined period during which the resources were available for batch processing.
To monitor a batch group:
  1. Click Monitor Batch from the Header panel.
    The Monitor window is displayed.
  2. Select the Batch Group from the Select drop-down and then select the Batch Run ID from the Run ID drop-down.
  3. Click Start Monitor.
    The result is displayed in Visualization and List View tabs. Details of these tabs are as follows:
    • The Visualization tab displays the details in the form of a chart represented with the following details:
      • Batch Status: Displays the batch status, the different batch status are NOT-STARTED, ON-GOING, SUCCESSFUL, FAILED, INTERRUPTED, EXCLUDED, HELD, and UNDEFINED.
      • Batch Start Time: Displays the batch start time details.
      • Batch End Time: Displays the batch end time details.
      • Batch Details: Mouseover the task to display its status and details.
    • The List View tab displays the details in a tabular form with the following details:
      • More Information: The message returned by the Rest Service.
  4. If you wish to stop the monitoring, select Stop Monitor. You can also specify the Start and Stop Monitor options along with refresh interval in the Refresh every seconds and minutes fields.
    • You can select the refresh interval and the duration for the auto refresh. The refresh interval is defaulted to 5 seconds and duration is defaulted to 5 minutes. That is the refresh happens every 5 seconds for next 5 minutes.
    • Range of interval input must be between 5 to 60 seconds and range of duration.
    • Input should be between 5 to 180 minutes.
    • You can use the Stop Monitor button to stop the auto refresh.
  5. To restart the Batch Group, select Restart.
  6. To rerun the Batch Group, select Rerun.
  7. To interrupt the Batch Group, select Interrupt.
    To view the log information about the batch group, click View Log in the List Viewtab.
