4.3 Create the Installation, Download, and Metadata Repository Directories
To install the application, create the following directories:
- OFS MMG Download Directory (Optional): This is the directory where the downloaded installer or patches can be copied. Create a download directory and copy the OFS MMG Application Pack Installer File (archive). Assign 755 permission to this directory.
- Temporary Directory: This is the default
temporary directory where the installation files are stored for a short time to
support faster installation. Configure adequate space on the
/tmpdirectory. It is recommended to allocate more than 10 GB of space. Assign 755 permission to this directory and disable theNOEXECoption.Note:
If theNOEXECoption is enabled, the extraction of files by the installer into the/tmpdirectory is prevented and the binaries will not execute in the directory, hence resulting in failure of the installation. - OFS MMG Installation Directory (Mandatory): Create an installation directory where the product binaries are installed. Assign 755-user permission to the Installation Directory.
- OFS MMG
Staging/Metadata Directory (Mandatory):
This is a directory to hold the
application metadata artifacts and additionally, act as the staging area for the
flat files. This directory is also referred to as
FTPSHARE. Create a Staging or Metadata Repository Directory to copy data files, save data extracts, and so on.Note:
Ensure that the OFS MMG Staging Directory is not set to the same path as the OFS MMG Installation Directory and is not a sub-directory inside the OFS MMG Installation Directory.
