4.2.3 Create the MMG Studio Schema
You must create an Oracle User to create the MMG Studio Schema. For more details, see Creating an Oracle User section.
Assign the following grants:
GRANT CONNECT, CREATE TABLE, CREATE VIEW, CREATE SEQUENCE TO
<mmgstudio_schema_name>;
A new user group created in MMG which requires permission for Studio
operations, is to be added in the following files:
- mmgstudio/conf/application.yml
- mmgstudio/conf/ofsaa-permissions.init.yml
Make sure the groups are in upper case, as AAI groups are always in upper case.
