5 Access MMG from Analytical Applications Infrastructure
You can now access the MMG Application and its features from
AAI.
Prerequisite
- To access the MMG application from AAI, log in to My Oracle Support, and search for 36336349 patch under the Patches & Updates tab, download and apply it.
- A valid MMG setup should be up and running.
Embedding the OFS MMG UI from the OFS AAI page is supported only when both OFS AAI and OFS MMG use the same protocol (either both HTTP or both HTTPS). Mixed protocol usage may cause authentication/session failures due to browser security restrictions.
To access the MMG application, perform the following steps:
