Add Python Paragraph
- Click Add Python Paragraph in Model Studio to add a
python paragraph in the Notebook and add the following scripting
instructions.
- To fetch connection objects:
conn = mmg.getConnection(<workspace name>)This creates a cx_oracle based connection object to the datadom of the workspace being passed:
- To fetch current Notebook and Model Objective details, use
the following predefined parameters:
currentNotebookId- fetches the current notebook IDobjectiveId- fetches the current objective ID
To fetch the runtime parameters supported in Model Studio runtime or to access optional parameters passed from scheduler services:- To access predefined batch runtime parameters
like
taskid,batchrunid, andficmisdatepassed during the model execution from scheduler, use the following variables : $BATCHRUNID$, $TASKID$, $FICMISDATE$.Example:
%python print('BATCHRUNID value is : ${$BATCHRUNID$}') print('TASKID value is : ${$TASKID$}') print('FICMISDATE value is : ${$FICMISDATE$}') - To access any optional parameters passed during
the model execution from scheduler, use the below sample
script:
%python print('threshold value is : ${threshold}')
Threshold is the optional parameter passed during the model execution.Note:
For more details on the predefined functions available in MMG for python scripting, see Appendix -I.Click the icon to run the script.
The execution result from the Pipeline Canvas screen is not displayed in the notebook tab. - To fetch connection objects:
