B Public APIs for Scheduler Operations
- All the below APIs are POST requests.
- All the APIs accept below values in request header:
- ofs_tenant_id - Optional
- ofs_service_id - Optional
- ofs_workspace_id - Respective workspace id where the batch needs to be created
- ofs_remote_user – MMG login user The ofs_workspace_id and ofs_remote_user are mandatory fields.
Base URL:
http(s)://<MMG_Service_HostName>:<MMG-Service_Port>/<CONETXTNAME>/
Table B-1 APIs for Scheduler Operations
| Functionality | API | Sample Request JSON | Sample Response JSON | Comments |
| Execute Immediate | rest-api/v1/external/trigger |
{ "batchName": "batch1", "batchType": "rest", "includedTasks":"task1,task2", "excludedTasks":"task1,task2", "heldTasks":"task1,task2" } |
{ "severity": "info", "summary": "Object triggered successfully with Run Id: batch1_2022-08-17_1660721567845_1", "batchRunId": "batch1_2022-08-17_1660721567845_1", "details": "Object triggered successfully.", "status": "success", "statusCode": "0" } |
| Execution Status | rest-api/v1/external/status |
{ "batchRunId": "batch1_2022-08-17_1660721567845_1", "tasks":["task1","task2"] } |
{ "severity": "info", "batchRunId": "batch1_2022-08-17_1660721567845_1", "taskStatusList": [ { "taskCode": "task1", "taskStatus": "SUCCESSFUL", "statusCode": "0" }, { "taskCode": "task2", "taskStatus": "EXCLUDED", "statusCode": "4" } ], "batchStatusCode": "0", "batchList": [], "batchStatus": "SUCCESSFUL", "status": "success", "statusCode": "0" } |
If not passed, then response will contain status all the tasks inside a batch. |
| Rerun | rest-api/v1/external/rerun |
{ "batchName": "batchgroup1", "batchRunId": "batchgroup1_2022-08-17_1660720814942_1" } |
{ "severity": "info", "summary": "Object triggered successfully for rerun with Run Id: batchgroup1_2022-08-17_1660730049819_1", "batchRunId": "batchgroup1_2022-08-17_1660730049819_1", "details": "Object triggered successfully.", "status": "success", "statusCode": "0" } |
| Restart | rest-api/v1/external/restart |
{ "batchName": "MMG_R1", "batchRunId": "MMG_R1_2022-07-15_1657867378160_1" } |
{ "severity": "info", "summary": "Object triggered successfully for restart with Run Id: MMG_R1_2022-07-15_1657867378160_1", "batchRunId": "MMG_R1_2022-07-15_1657867378160_1", "details": "Object triggered successfully.", "status": "success", "statusCode": "0" } |
| Interrupt | rest-api/v1/external/interrupt |
{ "batchName": "B2001", "batchRunId": "B2001_2022-05-22_1653222717896_1" } |
{ "summary": "Execution interrupted successfully for Run Id: B2001_2022-05-30_1653233511394_1", "severity": "info", "batchRunId": "B2001_2022-05-30_1653233511394_1", "details": "Execution interrupted successfully.", "statusCode": "0", "status": "success" } |
Table B-2 Failed Response Body
| Failed Sample Response JSON | Description |
| Batch Status Failed |
{ "severity": "info", "batchRunId": "BT-BI-EXCHG_RATES_EOD_2022-05-27_1653662703599_1", "batchStatusCode": "-1", "batchList": [], "batchStatus": "FAILED", "statusCode": "0", "status": "success" } |
| Object Not found |
{ "severity": "error", "summary": "Object does not exist.", "details": "Object does not exist.", "error": { "errorCode": "OBJECT_NOT_EXIST", "errorMsg": "Object does not exist." }, "statusCode": "-3", "status": "failed" } |
Table B-3 Status Codes in the Response Body
| Status Code | Description |
| 0 | Success |
| 1 | Not Started |
| 2 | Ongoing |
| 4 | Excluded |
| 5 | Held |
| -1 | Failure |
| -2 | Interrupted |
| -3 | Object does not exist |
| -4 | Invalid arguments passed in request/not enough parameters in the Request body |
| -5 | Invalid request headers/request headers missing |
| -6 | No executable job is present |
| -7 | Job is already interrupted |
