9.1.5.2.10 Task Definitions of a Batch/Batch Group
You can modify the task definition state in the Batch Execution window to exclude or hold the defined task in a Batch from execution. The excluded tasks are therefore assumed to have completed execution and get excluded during the Batch Run.
While executing or scheduling a batch group from the Schedule Batch window, you can:
  • Exclude a task or include the excluded task.
  • Hold a task or release the held task.
