Configuring R Interpreter
Make sure to configure the interpreter config and set the correct path for R binary
(zeppelin.R.cmd)
and the path to Python environment which has the
IRkernel installed (zeppelin.python)
In config.sh there is a new parameter:
export R_PYTHON_HOME=##R_PYTHON_HOME##
This is the Python Conda environment path till
<PATH TO
YOUR CONDA ENV>/bin/
python created following steps mentioned in 5.9,
which will set the zeppelin.python property
in
mmg-studio/server/builtin/interpreters/r.json
file.
The other property mentioned for R binary
(zeppelin.R.cmd)
is also set in above path the default value is R
so make sure that the user starting the services has access to R and alias is set or
change the property according to the path of R binary.
Steps to enable TLS during R Interpreter InstallationSteps to enable TLS during R Interpreter Installation:
- Download
Rserve_1.8-10.tar.gz
from this link: https://cran.r-project.org/src/contrib/Archive/Rserve/ - Install openssl-devel - [yum install openssl-devel]
- Execute below cmd:
R CMD INSTALL --configure-args="--with-ssl-headers=/usr/include --with-ssl-libraries=/usr/lib64" Rserve_1.8-10.tar.gz
The below steps can be executed from R session to check that Rserve configuration is working before starting the services:
Start R from
Terminal/Putty and execute the below commands:
library(Rserve)
Rserve(args="--RS-conf <Rserve.conf file location including file name> --no-save")
