5.13.4.1 Installing ROracle Library
Prerequisites
DBI is one of the dependencies for using this library.
- Installing DBI
- curl- O https://cran.r-project.org/src/contrib/ROracle_1.3-1.1.tar.gz
- R CMD INSTALL DBI_1.1.1.tar.gz
Procedure
To install ROracle Library, follow these steps:
- For ORD 3.6.1/R 4.1.2
- Install Oracle Instant Client Sdk Package. This is required for additional header files and an example makefile for developing Oracle Applications with Instant Client.
- Oracle client lib must be present in PATH. In the .profile file, set
PATH to include the appropriate
$ORACLE_HOME/bin
path.For example:
PATH=$JAVA_HOME/bin:$ORACLE_HOME/bin
- R CMD INSTALL
--configure-args='--with-oci-lib=<absolute-path-to-oracle-client-lib>
--with-oci-inc=<absolute path to instantclient_21_5>/include' ROracle_1.3-1.1.tar.gz
For example:
R CMD INSTALL --configure-args='--with-oci-lib=/scratch/users/oracle/app/oracle/product/19.3.0/client_1/lib --with-oci-inc=/scratch/users/oracle/instantclient-sdk/instantclient_21_5/sdk/include' ROracle_1.3-1.1.tar.gz
