4.4.2.1 Java Settings
To configure the Java Settings, refer the following table:
Table 4-2 Java Settings
Description | Example Value |
In the .profile file, set JAVA_BIN to include the JDK absolute path.
For example: JAVA 17 |
Table 4-3 Java Settings
In the Ensure that SYMBOLIC links to JAVA installation are not set in the PATH variable. |
Note: OFS STSA does not support OpenJDK. |
For example: JAVA_BIN
Note: During upgrade from 81270 to 81310 build, since 81270 is running on JDK-11.0.13 and 81310 needs to be running on JDK-17, the certificates needs to be imported again to JDK-17. |
