10.4.1.2.2.2 Build via AutoML
The AutoMLx python package automatically creates, optimizes and explains
machine learning pipelines and models. The AutoML pipeline provides a tuned ML pipeline
that finds the best model for a given training dataset and a prediction task at hand.
AutoML has a simple pipeline-level Python API that quickly jump-starts the data science
process with an accurate tuned model.
The AutoML pipeline consists of five major stages of the ML pipeline:
preprocessing, algorithm selection, adaptive sampling, feature selection, and model
tuning.
These pieces are readily combined into a simple AutoML pipeline which
automatically optimizes the whole pipeline with limited user input/interaction.
The user needs to manually install the Oracle-AutoMLX Python package.Figure 10-53 Build via AutoML
Follow these steps to build via AutoML:
